fisico30
- 374
hello forum,
i am struggling with the conceptual understanding of this problem:
Given two blocks, one on top of the other. There is friction between the two blocks.
The upper block is pulled with a force F. Thanks to friction, as long as F is smaller or equal to the static friction f_s(max) the objects will move, accelerate together, withouth having the top block slide over the lower block...
The free-body diagram of the top block involves only two forces in the horizontal direction: F and f_s. F=f_s for the top block not to slide while being pulled.
But that seems from the frame of reference of the lower block...
If we are observing the situation from the ground, the top (and bottom) block is accelerating, moving, so a net force need to be there...
The upper block is not moving relative to the lower block (relative velocity=0).
What is the correct frame of reference to use? I would say the one fixed with the ground (because inertial). But that would imply a net force on the top block, while we just have
F=f_s
thanks
fisico30
F=f_s
thanks
fisico30
