JustinLevy
- 895
- 1
I want to first explain my current understanding and motivation so you guys can whip me into shape in case I'm misunderstanding the starting point -- SR and linear transformations.
So, we can write the laws of electrodynamics in terms of the electromagnetic field tensor [itex]F^{\alpha \beta}[/itex] as such:
The Lorentz force law:
[tex]K^\alpha = \frac{dp^\alpha}{d\tau} = q v_\beta F^{\alpha \beta}[/tex]
And maxwell's equations:
[tex]\Large{\Large{F^{\alpha \beta}}_{ ,\beta} = \mu_0 j^\alpha}[/tex]
[tex]\Large{F_{ \alpha \beta , \gamma } + F_{ \beta \gamma , \alpha } + F_{ \gamma \alpha , \beta } = 0 }[/tex]
I remember seeing a thread here about a paper which used the covarient form of the electromagnetic field tensor in an inertial coordinate system to define what the electric and magnetic fields were.
[tex]F^{\alpha \beta} = \left( \begin{array}{cccc}
0 & -E_x/c & -E_y/c & -E_z/c \\
E_x/c & 0 & -B_z & B_y \\
E_y/c & B_z & 0 & -B_x \\
E_z/c & -B_y & B_x & 0 \end{array}\right)[/tex]
They then worked out what maxwell's equations would look like (in terms of E and B) in other coordinate systems. For inertial frames, the metric [itex]g^{\alpha \beta}[/itex] is just diagonal -1,1,1,1. So in inertial frames finding [itex]F_{\alpha \beta} = g_{\alpha \gamma} g_{\beta \delta} F^{\gamma \delta}[/itex] involves just changing the sign of the components in the first row and collumn.
For general linear transformations (not necessarily lorentz transformations), by the paper's definition [itex]F^{\alpha \beta}[/itex] is the same, but now that [itex]g_{\alpha \beta}[/itex] is not just a simple diagonal -1,1,1,1 this means [itex]F_{\alpha \beta}[/itex] in terms of E and B will look quite different.
They used this to work out, as an example, what maxwell's equations would look like in terms of E and B for some non-inertial coordinate systems defined by a (non lorentz) linear transformation from an inertial coordinate system.
Now, what I would like to do is use this method to get some vector field equations of electrodynamics for a uniformly accelerating observer. This involves non-linear transformations, and so the components of the transformations themselves need to somehow depend on position? I'm not sure how to even write this.
I'd like to start much simpler to begin with. So maybe someone can help me work through how to write transformations in which the components depend on position, and I'll try to work out the metric according to these coordinates. Then I can check the metric by looking at the time measured by this accelerating observer between two events on his path (which is just the length of his world-line so it is easy to check the answer).
Please go easy on me, I'm (clearly) still learning.
EDIT: I found the paper again -
T. Chang, Physics Letters 70A, 1 (1979)
Hmm... I know I still have a lot to learn, but while the math in the paper looks fine and makes sense to me, they seem to finish the paper with a paragraph of claims that seem (to me) ridiculous and makes it sound (again to me) that they don't even understand what they just calculated (for they somehow claim it may be possible to experimentally distinguish this and the "usual" maxwell's equations... but these ARE maxwell's equations, just in a different coordinate system. You can't experimentally "disprove" a coordinate system! Is this whole paper junk? The math looks fine, and the method/summary above looks fine to me ... am I misunderstanding something bigger here?) If their math is fine, let's just ignore they even wrote that last paragraph.
