Non-productive work while running
In summary, runners often twist in their upper body while running due to tightness in their shoulders. This can also cause their arms and legs to cross over the midline. The amount of extra energy expended in this twisting and counter-twisting is not well understood, but can be quantified through biomechanical analysis. The stored energy and amount lost when untwisting are important factors to consider, as well as the maximum angular velocity achieved in each half of the body. The model also needs to account for balancing forces and tension in the midriff.
spotmeter
Many runners twist in their upper body while they run. You can see this by watching the logo on their tee-shirt move sideways. You can also see it when their arms cross in front of their body instead of moving straight forward and back.
We have found that runners do this because of tightness in their shoulders. When they bring their right arm back, for instance, tightness in their right shoulder will twist their shoulders to their right, throwing their left arm across their body.
Less well known is that they also swing their right leg to their left to counter the twisting to their right in their upper body. In some cases, they may even cross over the midline.
We would like to be able to compute the amount of extra work, or extra energy expended, to twisting and counter-twist like this while running.
We are able to quantify the amount of lateral movement of the arms and legs with a biomechanical analysis of a runner, but we don't know how to quantify the amount of work or energy expended.
Any help very much appreciated.
It sounds to me like you want to analyze the runner's body in terms of two counter-rotating pieces, with their associated moments of inertia, that maintain zero net angular momentum. The kinetic energy of rotation gets stored in some kind of twisting potential, and then some is returned when they untwist and some is dissipated. So the two questions there would be, what is the magnitude of the work done by the two pieces on each other (i.e., the magnitude of the stored energy), and what fraction of that is lost when they untwist and prepare for the next step? It seems to me rather a lot gets lost, so the most important question might be the magnitude of the twisting energy we are talking about. That might be characterized by the maximum angular velocity they achieve-- the twisting kinetic energy is Iw2/2, where I is the moment of inertia of each half (upper and lower body), and w is the angular speed of each half. If the model is good, the product of Iw should be about the same for upper and lower halves-- maintaining zero net angular momentum. That means the work done is just the action/reaction torque each half applies on the other half, integrated over twist angle. Whichever part twists more gets more of the work done. What makes it tricky is that the body might generate balancing but opposite forces on the same part (upper or lower), so that work would be done and likely dissipated without showing up in the w. Estimating that contribution would be difficult, and might have to do with the tenseness of the midriff.
Related to Non-productive work while running
What is non-productive work while running?
Non-productive work while running refers to any tasks or activities that do not contribute directly to the physical act of running. This can include things like checking your phone, stopping to chat with someone, or taking unnecessary breaks.
Why is non-productive work while running discouraged?
Non-productive work while running is discouraged because it can hinder your progress and decrease the effectiveness of your workout. By taking breaks or engaging in other tasks, you are not fully utilizing the time and energy you have set aside for running.
How can non-productive work while running affect my performance?
Non-productive work while running can have a negative impact on your performance by disrupting your focus and breaking your rhythm. It can also lead to a decrease in overall endurance and speed, making it more difficult to reach your running goals.
What are some strategies for avoiding non-productive work while running?
One way to avoid non-productive work while running is to plan your route ahead of time and eliminate potential distractions. You can also set specific goals for each run and hold yourself accountable to stay on track. Additionally, finding a running partner or joining a running group can help keep you motivated and focused.
Are there any benefits to non-productive work while running?
While it is generally discouraged, there can be some benefits to non-productive work while running, such as taking a quick water break or stretching out sore muscles. However, these should be done in moderation and not used as an excuse to constantly engage in non-productive activities while running.
