Object Thrown from building help
  • Thread starter xtrubambinoxpr
  • Tags
    Building
In summary, the boy throws a stone from the top of the building that is 45 m high. It lands 64 m away. The time of flight, initial speed, and speed and angle with respect to the horizontal of the velocity vector at impact are all found.
xtrubambinoxpr
87
A boy throws a stone from the top of the building that is 45 m high. It lands 64 m away. Find the following:
a) time of flight
b) initial speed
c) speed and angle with respect to the horizontal of the velocity vector at impact
2a) throwing the stone with more force (1.5 times harder) multiplies the time it takes to reach the ground by?
2b) The horizontal component of the velocity is multiplied by what factor?
2c)how many times further does the stone land away from the building
d=1/2gt^2
Xf=Xi+Vot
a) I figured out that since it take 3.03 seconds to drop 45m then it must also take 3.03 for it to land when being thrown horizontally. solved using d=1/2gt^2
b) knowing time: 64=Vot => 64/3.03=Vo ----> Vo = 21.13m/s
everything else I can't seem to figure out
For part (c), can you determine the vertical component of the velocity of the stone at impact? How about the horizontal component?
The total velocity would be sqrt(ViSinθ^2 + ViCosθ^2) so would it be ViSinθ = -(sqrt(ViCosθ^2))??
Well, you don't know the angle of impact (yet), so that wouldn't be helpful. And the magnitude of the final velocity won't be equal to the initial velocity Vi, since the stone will be gaining energy as it falls from its initial elevation to the ground below.
So, let me offer another viewpoint. You know that the horizontal and vertical components of projectile motion are independent (at least until the flying object hits something!). Consider each component separately. Start with the vertical component. How fast will the stone be traveling vertically having fallen 45m from rest?
it would be falling with V = -gt. d=1/2gt^2 would get me 3.03 seconds to fall from rest. so -gt = -29.71m/s that is the vertical component itself? considering the horizontal component always stays the same because no force acts on it to provide any accel.
Right. So now you know both the vertical and horizontal components of the velocity at impact (assuming you can calculate the horizontal component given your distance and time).
What can you determine from that?
gneill said:
Right. So now you know both the vertical and horizontal components of the velocity at impact...
that final velocity of impact is sqrt(29.71^2 + 21.12^2) will give me the velocity right before it hits the ground.
^^ I think that is wrong
the only other thing I can think of is that the components can be further broken down to i + j form and then placed into each other to get one final equation?
The components are already in "i + j form", since one is vertical and the other horizontal; they are at right angles to each other, and directed along coordinate axes. So essentially they are orthogonal vectors.
So your final velocity magnitude is okay. What about the angle?
if they are in I + J form already then tan^-1(j/i) gives me the angle measure which is -54.6 degrees?
Sure. Looks good.
Likes 1 person
Got it! took a second look at it and became so obvious why. thank you!
It's always a good feeling when what looked difficult suddenly becomes obvious :smile:
Cheers!
Related to Object Thrown from building help
1. What are the potential risks associated with throwing an object from a building?
Throwing objects from a building can pose a threat to the safety of people below. The object could hit someone and cause injury or damage to property. It can also create a distraction and potentially cause accidents.
2. How does the weight and shape of an object affect its trajectory when thrown from a building?
The weight and shape of an object can significantly impact its trajectory when thrown from a building. Heavier objects will fall faster and have a shorter horizontal distance, while lighter objects may have a longer horizontal distance. The shape of the object will also affect how it travels through the air, with more aerodynamic shapes having a smoother and more stable trajectory.
3. Is it ever safe to throw an object from a building?
No, it is never safe to throw an object from a building. Even if there is no one below, the object can still cause damage to property or create a distraction that could lead to accidents. It is important to find safe alternatives for disposing of unwanted objects.
4. Can throwing objects from a building affect the structural integrity of the building?
Yes, throwing objects from a building can potentially damage the structure of the building. Repeated impact from objects can weaken or crack windows, walls, or other parts of the building. This can compromise the safety of the building and put its occupants at risk.
5. What should I do if I witness someone throwing objects from a building?
If you witness someone throwing objects from a building, it is important to report it to the appropriate authorities immediately. Throwing objects from a building is a dangerous and potentially illegal act, and it is important to prevent any potential harm to others. Do not attempt to confront the person yourself.
