Ohmic Losses In Capacitor Discharge
In summary, the conversation discusses two sources of power, one with ten capacitors and one with one larger capacitor, both containing the same amount of energy. The advantage of the source with ten capacitors is that they can be discharged at set intervals, creating a longer and lower current pulse. However, the disadvantage is that the smaller capacitors have a higher ESR, potentially wasting more energy than the larger capacitor. The question is raised about whether the total energy lost due to ohmic losses would be the same if the ten capacitors were discharged in close intervals. The expert explains that the total current and resistance would be the same in both cases, making the power loss the same. A question is then asked about using SCR's to switch power
axi0m
60
Let's say that we have two capacitive sources of power:
1) ten parallel 450V 1800uF 138.8mOhm-ESR capacitors​
2) one 450V 18000uF 13.88mOhm-ESR capacitor​
Both sources contain 1,823J of energy. The source containing ten capacitors is advantageous for my purposes due to the fact that the capacitors can be discharged at set intervals, thus creating a longer, lower current pulse than the one large capacitor. My main priority is overall system efficiency.
The disadvantage with lower-capacitance capacitors is that they have a much higher equivalent series resistance (ESR.) Being that resistance in a circiut dissipates power, thus wasting energy, I would expect, in my mediocre electrical knowledge, that the source containing ten high-ESR capcitors would waste more energy than the other, thus leading to lower overall system efficiency.
However, my source of confusion is the fact that if all ten capacitors from the first source were placed in parallel and discharged simultaneously, the total resistance would be given by the equation below, which dictates total resistance of resistors in parallel, in this case, the ESR of the ten capacitors:
By this equation, the total ESR of all ten capacitors connected in parallel would be 13.88mOhms, the same ESR as the one large capacitor. Is it true that if all ten capacitors from source one were discharged not simultaneously, but in very close intervals, the total energy lost due to ohmics losses would be the same as in source two, the one large capacitor?
As always, thanks in advance for your help -- it's much appreciated.
The ESRs are not in parallel. They are in series with a capacitor and the combinations are in parallel.
However the effect is the same. Each of the smaller capacitors would discharge at 3242 amps
(450 / .1388) initially.
The large capacitor would discharge at 32420 Amps.
So, yes, the total current would be the same and the resistance is effectively the same, so the power loss is the same.
Yes.
vk6kro said:
Yes.
Haha, I checked your first reply from my phone and somehow overlooked the end of your post where you said power loss would be the same. Then by the time I saw it and deleted my post, you already replied. You're good! ;-)edit:
I see now you edited it. Sneaky sneaky...
Yes, I extended the comment a bit. Stating the obvious, I suppose.
These are serious currents, though. Are you sure these capacitors are rated for such currents?
The large capacitor would be dissipating 14 589 000 watts if only briefly.
I'm just having a hard time conceptualizing how adding more capacitors in parallel decreases total resistance, or ESR. It seems like some kind of double-slit photon experiment.
Yes, pretty sure. Aluminum electrolytic capacitors are used quite frequently for fast-discharge experiments including various electromagnetic launchers. I've even read about a representitive from Cornell-Dubilier that discussed using the same type of capacitor for 40kA+ discharge experiments -- from a single capacitor.
On a very related topic, I have another question.
I'm thinking of using the ten-capacitor bank with an SCR on each capacitor. Each SCR would be controlled by some kind of microprocessor or IC and could be fired at any given interval.
It appears that each capacitor will discharge at around 3kA+. Obviously, an SCR that is listed at this current would be well outside of a reasonable budget. I'm thinking that for such a short pulse duration, an SCR could handle around 10x its normal current limit -- does that seem reasonable? Thus, I could find one that's closer to 300A.
axi0m said:
I'm just having a hard time conceptualizing how adding more capacitors in parallel decreases total resistance, or ESR. It seems like some kind of double-slit photon experiment..
Suppose the total sum current is I, and the ESR is R ohms for each of 10 capacitors. Then the power loss in each ESR is (0.1 I)2 R = 0.01 I2 R. So the sum of the losses in 10 capacitors is 0.1 I2 R, or I2 R/10.
Quick question -- I'm interested in http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260442854571&ssPageName=STRK:MEWAX:IT" to switch power for the capacitors. It says SCR, however, I don't see a wire or even a terminal for the gate. I asked the seller about it, if it was really an "SCR", the person said simply that they didn't know.
Could this be anything but an SCR? ...being that it doesn't have another wire or visible terminal. I'm assuming the terminal for the gate is on the other side or something.
Related to Ohmic Losses In Capacitor Discharge
1. What are Ohmic losses in capacitor discharge?
Ohmic losses in capacitor discharge refer to the energy that is dissipated as heat due to the resistance of the circuit components during the discharge process.
2. Why do Ohmic losses occur in capacitor discharge?
Ohmic losses occur because no circuit is perfectly conductive, and all circuit components have some level of resistance. This resistance causes energy to be lost as heat during the discharge process.
3. How do Ohmic losses affect the discharge process?
Ohmic losses reduce the overall efficiency of the discharge process, as the energy is not fully transferred to the intended output. This can result in a slower discharge rate and a decrease in the amount of energy available for use.
4. Can Ohmic losses be minimized?
Yes, Ohmic losses can be minimized by using components with lower resistance values and optimizing the circuit design to reduce the overall resistance. However, it is impossible to completely eliminate Ohmic losses.
5. How do Ohmic losses impact the lifespan of a capacitor?
Ohmic losses can cause the temperature of the capacitor to increase, which can decrease its lifespan. The heat generated by the losses can also cause internal damage to the capacitor, leading to a shorter lifespan.
11K
