Oxygen/cargon monoxide when burning
  • Thread starter Georgevan
In summary, there is no plant or substance that can be burned to release oxygen and neutralize carbon monoxide. Combustion, by definition, involves the release of oxygen and cannot result in a substance other than oxygen. While some chemicals and processes can generate oxygen, they are not a viable solution for neutralizing carbon monoxide. Additionally, carbon monoxide is not a byproduct of proper combustion.
Georgevan
is there anything that gives off oxygen when burning rather than carbon monoxside? What I am wondering is if there is something that when burned releases oxygen that would combine with carbon monoxide and either neutralize the carbon monoxside or over ride it in some wayy
Chemistry news on Phys.org
Combustion is by definition, a rapid, exothermic oxidation reaction, so no.
That's not exactly true. Though that's the definition of "combustion", it does not implly starting with pure oxygen and ending with something other than oxygen. If the oxidizer is a chemical and the reaction has an overabundance of oxygen, it can, indeed release oxygen in the reaction. This is how oxygen generators in firefighting equipment work: http://en.wikipedia.org/wiki/Chemical_oxygen_generator
The shuttle boosters use ammonium percholrate as an oxidizer, which is NH4ClO4 http://en.wikipedia.org/wiki/Ammonium_perchlorate
Sodium can "burn" in chlorine with a flame.
You can generate oxygen by replacing it with a more reacting compound like fluorine out of it's oxides or compound. The reaction generates heat but I doubt it that you could call that combustion.
Some chemicals are unstable and could release O2 like russ said.
what I am thinking of and should have made clear is that I am wondering if there is a plant of some sort that when burned would give off oxygen that would combine with the carbon monoxide with the result that the carbon monoxide would be neutralized.
That no. But CO burns quite well in normal air.
...and if things are burned properly, CO isn't a product of combustion anyway. I'm still confused...
FAQ: Oxygen/cargon monoxide when burning
What is oxygen/carbon monoxide when burning?
Oxygen and carbon monoxide are both gases that are involved in the process of burning. Oxygen is necessary for combustion to occur, while carbon monoxide is a byproduct of incomplete combustion.
What are the effects of inhaling carbon monoxide?
Inhaling carbon monoxide can be dangerous and even deadly. It can cause headaches, dizziness, nausea, and fatigue, and can lead to more serious symptoms such as loss of consciousness, organ damage, and death.
Why is ventilation important when burning with oxygen?
Ventilation is important when burning with oxygen because it helps to ensure that the combustion process is occurring safely and efficiently. Proper ventilation can prevent the buildup of harmful gases, such as carbon monoxide, and can also help to control the amount of oxygen present in the burning process.
How does carbon monoxide form during burning?
Carbon monoxide forms during burning when there is not enough oxygen present for complete combustion to occur. This can happen when there is a lack of ventilation, or when there are impurities in the fuel source.
What are some safety precautions to take when burning with oxygen?
Some safety precautions to take when burning with oxygen include ensuring proper ventilation, using the correct amount of oxygen for the fuel source, and having a carbon monoxide detector in the area. It is also important to always follow the manufacturer's instructions and never leave a burning process unattended.
10K
