Paradox: Thermodynamic equilibrium does not exist in gravitational field
  • #106
A.T. said:
Two identical particles simply swap their velocities in elastic 1D collision. So if you don't label them, and don't look, then afterwards you cannot tell if there was a collision, or if they just passed through each other. Therefore in a very thin, one particle wide cylinder of gas, the velocity distribution is not affected by whether the particles interact or just pass through each other.
That means that in 1D, particle interactions with each other cannot redistribute the kinetic energy and thus equalize the energy spectrum and thus make the system evolve towards the thermodynamic equilibrium. Only collisions with the floor or ceiling will be able to do that.
The situation is quite different in higher dimensions.
Science news on Phys.org
  • #107
The one-particle-wide-cylinder I was considering has a floor and ceiling, just like your 3D box. An the 1D math shows that particle-particle-interaction makes no difference to energy redistribution, just like you found for your 3D box (if I understand you correctly).
Maybe. But 1D seems to get the same (qualitative) result as you got for the 3D case, no?
  • #108
I meant something else: Interactions push the system towards thermodynamic equilibrium (they only don't for identical particles in 1D, as you have shown) by redistributing energy. If the system has not reached equilibrium yet, then the interactions will be important. In my analysis, I assume that the system is already in equilibrium. Once the equilibrium has been reached, further interactions will make no difference.
  • #109
So, for example, the equilibrium profile of density in a vessel should be independent on whether the vessel contains gas in a low density (and they rarely collide with each other, compared to walls) or high density (many collisions between wall and wall). And the collision cross-section should matter for the process of setting up equilibrium - but not for the equilibrium once established. Right?
  • #110
You're right. The density ##\rho(z)## as a function of altitude ##z## will be the same up to a multiplicative constant. We should just remember that we are talking about an ideal gas.
Did you mean many collisions between particle and particle?
Exactly.
  • #111
Ah, I see that it was badly written.
I meant that a particle has many collisions with other particles between collisions of the particle with a wall and a collision of the same particle with a different wall.
  • #112
I see, no problem. Thinking about this property, there is also a related quantity called mean free path.
  • #113
anuttarasammyak said:
Comparing it with the bouncing-ball-system, I observe the difference, damping is slower in thermal equillibrium.
Please find https://www.wolframalpha.com/input?i2d=true&i=Divide[2,3Sqrt[pi]]Divide[1,x]\(40)Divide[Sqrt[pi],2]-Gamma\(40)Divide[3,2]\(44)x\(41)\(41)+Divide[1,Sqrt[pi]]\(40)Divide[1,2]+Gamma\(40)Divide[1,2]\(44)x\(41)+Divide[1,3]Sum[Power[\(40)-1\(41),n],{n,0,100}]Divide[\(40)Divide[1,2]\(41)!,\(40)Divide[1,2]-n-2\(41)!\(40)n+2\(41)!]Power[x,Divide[\(40)n+1\(41),2]]Gamma\(40)Divide[3,2]-n+2\(44)x\(41)\(41)-Divide[x+1-Power[e,x],x-x*Power[e,x]] wolfram calculation of height averages,
<z>/h of independent bouncing balls - <z>/h of thermal equillibrium ##\leq## 0
where parameter x is ##mgh\beta##. They coincide with 1/2 at x=0 but do not coincide for x>0. I do not expect that higher order n terms which I cannot calculate due to compuring resource limit, would contribute so that they coincide.
  • #114
  • #115
Demystifier said:
$$H({\bf x},{\bf p})=\frac{{\bf p}^2}{2m}+gz$$
I think that ##m## is missing at the end of the formula. Hamiltonian of a point mass in homogeneous gravitational field is
$$H({\bf x},{\bf p})=\frac{p^2}{2m}+mgz.$$
  • #116
Of course, thanks for the correction! :smile:
