Paralle plate capacitor (with dielectric)
V_0}{d}\cdot(1-\epsilon_r) + \epsilon_0\epsilon_r\hat{x}\frac{V_0}{d\epsilon_r}\cdot(1-\epsilon_r) = -\epsilon_0\hat{x}\frac{V_0}{d}(1-\epsilon_r) + \epsilon_0\epsilon_r\hat{x}\frac{V_0}{d} = \epsilon_0\hat{x}\frac{V_0}{d}(1-\epsilon_r) + \epsilon_0\epsilon_r\hat{x}\frac{V_0}{d} = \epsilon_0\hat{x}\frac{V_0}{d}(1-\epsilon_r
FrogPad
810
EDIT: I figured it out.
A parallel-plate capacitor of width [itex] 2w [/itex], length [itex] L [/itex] and separation [itex] d [/itex] is partially filled with dielectric material of [itex] \epsilon_0 \epsilon_r [/itex]. A voltage [itex] V_0 [/itex] is applied.
1. Find [itex] \vec D [/itex], [itex] \vec E [/itex], [tex] \rho_S [/itex]
---------|---------|-------V0
NOTE: The dielectric is on the right side (I colored it red)
Note: Book convention uses [itex] \rho [/itex] as charge density.
Boundary Conditions:
[tex] B_{1t} = B_{2t} [/tex]
[tex] D_{1n} - D_{2n} = \rho_S [/tex]
[tex] \vec E = \frac{\vec D}{\epsilon} [/tex]
Ideal Parallel Plate:
[tex] \vec E = \hat e \frac{V_{12}}{d} [/tex]
We first assume the use of ideal conditions, thus the expressions above hold.
Next we note that the E field is directed from the top plate to the bottom plate. So we have,
[tex] \vec E_1 = -\hat z \frac{V_{12}}{d} =-\hat z \frac{V_{0}}{d}[/tex]
[tex] \vec E_2 = -\hat z \frac{V_{0}}{d} [/tex]
The only component of the E fields are tangential components. ie,
[tex] \vec E_1 = -\hat z E_t + \hat e E_n [/tex]
Where: [itex] \hat e [/itex] is a basis vector in some direction, and [itex] E_n = 0[/itex]
I'm basically trying to say that the E fields consist of no normal components to the interface.
Thus we satisfy our first BC with [itex] \vec E_1 = \vec E_t [/itex].
Moving on to the second BC we note:
[tex] \vec D_1 = \epsilon \vec E_1 = \epsilon_0 \vec E_1 [/tex]
[tex] \vec D_2 = \epsilon \vec E_2 = \epsilon_0 \epsilon_r \vec E_2 [/tex]
[tex] \vec D_1 = \epsilon_0 \left(-\hat z \frac{V_{-}}{d} \right) [/tex]
[tex] \vec D_2 = \epsilon_0 \epsilon_r \left(-\hat z \frac{V_{0}}{d} \right) [/tex]
I'm confused here (and probably above too).
So,
[tex] \vec D_1 - \vec D_2 = -\hat z \frac{\epsilon_0 V_0}{d} (1-\epsilon_r) [/tex]
Now the normal component is [itex] \hat -x [/itex] (is this right?). (The coordinate system I'm using is x is left to right, y is in and out of page, and z is up and down.)
So doing the dot product:
[tex] \hat n \cdot (\vec D_1 - \vec D_2) = \rho_S [/tex]
This implies, [itex] \rho_S = 0 [/itex]
... I'm just confused here. I don't understand this part at all. Any help would be great!
Hello,
Thank you for your post and for sharing your thoughts on the problem. From your attempt at a solution, it seems like you have a good understanding of the boundary conditions and how to apply them to this problem. However, I do see a few areas where you may be getting confused.
Firstly, your expression for \vec{E_1} is correct, but your expression for \vec{E_2} is not. Remember that the electric field inside a dielectric material is reduced by a factor of \epsilon_r compared to the electric field in vacuum. So, the correct expression for \vec{E_2} would be:
\vec{E_2} = -\hat{z}\frac{V_0}{d\epsilon_r}
Next, your expressions for \vec{D_1} and \vec{D_2} are also incorrect. Remember that the electric displacement vector, \vec{D}, is equal to \epsilon_0\vec{E} in vacuum, but in a dielectric material it is equal to \epsilon\vec{E}. So, the correct expressions for \vec{D_1} and \vec{D_2} would be:
\vec{D_1} = \epsilon_0\vec{E_1} = -\epsilon_0\hat{z}\frac{V_0}{d}
\vec{D_2} = \epsilon\vec{E_2} = -\epsilon_0\epsilon_r\hat{z}\frac{V_0}{d\epsilon_r}
Now, when you take the dot product of \hat{n} and (\vec{D_1} - \vec{D_2}), you should get a non-zero surface charge density. This is because the normal component of the electric displacement vector is not zero at the interface between the dielectric material and the vacuum. The normal component of \vec{D_1} is -\epsilon_0\hat{x}\frac{V_0}{d}, while the normal component of \vec{D_2} is -\epsilon_0\epsilon_r\hat{x}\frac{V_0}{d\epsilon_r}. So, the dot product would be:
\hat{n}\cdot(\vec{D_1} - \vec{D_2}) = -\epsilon_0\hat{x}\frac
FAQ: Paralle plate capacitor (with dielectric)
What is a parallel plate capacitor?
A parallel plate capacitor is a type of capacitor that consists of two parallel conductive plates separated by a dielectric material. It is used to store electrical energy by creating an electric field between the two plates.
What is the purpose of using a dielectric in a parallel plate capacitor?
The dielectric material is used to increase the capacitance of the parallel plate capacitor. It does this by reducing the electric field between the plates, thus allowing more charge to be stored on the plates.
How does the distance between the plates affect the capacitance of a parallel plate capacitor?
The capacitance of a parallel plate capacitor is directly proportional to the distance between the plates. As the distance increases, the capacitance decreases and vice versa.
What is the formula for calculating the capacitance of a parallel plate capacitor with a dielectric?
The formula for calculating the capacitance of a parallel plate capacitor with a dielectric is C = εA/d, where C is the capacitance, ε is the permittivity of the dielectric material, A is the area of the plates, and d is the distance between the plates.
How does the dielectric constant of the material affect the capacitance of a parallel plate capacitor?
The dielectric constant, also known as the relative permittivity, is a measure of how well a material can store electrical energy. The higher the dielectric constant, the higher the capacitance of the parallel plate capacitor will be.
