Perturbation theory to solve diff eq?
In summary: B(\vec{r})}Thus, in summary, to solve the inhomogeneous equation:\nabla f(\vec{r}) = \vec{A}(\vec{r})for b(\vec{r}), we can use the fact that A(\vec{r}) has 0 curl to rewrite the equation and then use the identity \nabla (fg) = f\nabla g + g\nabla f to simplify
vibe3
46
Hi all, I have a tricky problem in pertubation theory.
I have a function:
[tex]
f(\vec{r}) = P(\vec{r}) + \left( B(\vec{r}) + b(\vec{r}) \right)^2
[/tex]
where [tex] b(\vec{r}) [/tex] is a small perturbation and is equal to 0 when [tex] P(\vec{r}) = 0 [/tex]
Now, to solve the equation
[tex]
\nabla f(\vec{r}) = 0
[/tex]
for b(r) is fairly straightforward by noting that
[tex]
P + (B + b)^2 = C = B^2
[/tex]
using the fact that P = 0 ==> b = 0. And so,
[tex]
b(\vec{r}) = \frac{-P}{2B}
[/tex]
by expanding the above equation and neglecting the [tex]b^2[/tex] term. Now, my question is how do you solve the inhomogeneous equation:
[tex]
[/tex]
for b(r) where A is a known vector field with 0 curl?
Hello there,
Thank you for sharing your problem with us. Perturbation theory can indeed be tricky, but I believe I can offer some insights that may help you solve this inhomogeneous equation.
Firstly, let's take a closer look at the equation you are trying to solve:
We can rewrite this equation as:
\nabla \left( P(\vec{r}) + \left( B(\vec{r}) + b(\vec{r}) \right)^2 \right) = \vec{A}(\vec{r})
Expanding the squared term, we get:
\nabla \left( P(\vec{r}) + B^2(\vec{r}) + 2B(\vec{r})b(\vec{r}) + b^2(\vec{r}) \right) = \vec{A}(\vec{r})
Now, we know that P(\vec{r}) = 0 when b(\vec{r}) = 0, so we can simplify the equation to:
\nabla \left( B^2(\vec{r}) + 2B(\vec{r})b(\vec{r}) + b^2(\vec{r}) \right) = \vec{A}(\vec{r})
Next, we can use the fact that A(\vec{r}) has 0 curl, which means that it can be written as the gradient of a scalar function, say \phi(\vec{r}).
\nabla \phi(\vec{r}) = \vec{A}(\vec{r})
Substituting this into our equation, we get:
\nabla \left( B^2(\vec{r}) + 2B(\vec{r})b(\vec{r}) + b^2(\vec{r}) \right) = \nabla \phi(\vec{r})
Now, we can use the identity:
To rewrite our equation as:
B(\vec{r}) \nabla (2b(\vec{r})) + b(\vec{r}) \nabla (2B(\vec{r})) = \nabla \phi(\vec{r})
Since we know that B
FAQ: Perturbation theory to solve diff eq?
What is perturbation theory?
Perturbation theory is a mathematical method used to solve differential equations that cannot be solved analytically. It involves breaking down a complicated problem into a simpler one by introducing a small parameter or "perturbation" and then solving the equations iteratively.
What are differential equations?
Differential equations are mathematical equations that describe how a quantity changes over time or space. They involve derivatives and are commonly used to model physical systems in various fields such as physics, engineering, and biology.
When is perturbation theory used to solve differential equations?
Perturbation theory is used when the differential equations are too complex to be solved using other methods. It is particularly useful when the equations involve small variations or disturbances from a known solution.
What are the advantages of perturbation theory?
Perturbation theory allows for the approximation of solutions to complex differential equations, making them easier to solve. It also provides a deeper understanding of the behavior of a system and can be used to predict how it will respond to small changes.
What are the limitations of perturbation theory?
Perturbation theory can only be applied to systems with small perturbations and may not provide accurate solutions for large perturbations. It also requires a good understanding of the underlying system and can be time-consuming to apply, especially for higher-order perturbations.
