Photon Interval vs Areal Density for Changing Intensity
In summary, the emission rate of photons from an incandescent bulb decreases as the temperature decreases, while the areal density of photons remains constant. This is due to the decrease in collisions between atoms and molecules at lower temperatures, which results in a lower rate of photon emission. However, according to Planck's law, the number of photons per emission increases with higher temperatures, so the rate of emission cannot be constant.
greswd
764
When one reduces the intensity of let's say, an incandescent bulb (by varying the resistance, as seen in many homes), which decreases more, the photon frequency (not related to wavelength, but the time interval between photon emissions) or the areal density of the photons?
To what extent does each decrease?
The emissions of photon related to the frequency.
The intensity just can increase or decrease the number of photons, but the movement enargy of photons related to the frequency of light
I don't understand what you're saying.
can someone please help me
If the frequency of emission decreases the aerial density will do too. By the same proportion.
thanks. do you have any literature on this?
No. It's just a consequence of flux. If you double the flux you double the rate of that the photons pass through a shell. Given that they all travel at c, the speed of light, the density in the shell must be double.
No, you can double the flux by halving the interval and leaving the density unchanged. The photons will still travel at c.
I want to know the density and interval relationship for an incandescent bulb, or any other type of light source you know of.
Incandescent light bulbs emit light as a result of heat. We can treat the bulb as a black body source. The question you ask is really specific, I will answer according to my intuition however if I am mistaken feel free to correct.
A black body source emits light as a result of collisions between atoms and molecules in the atomic structure. As the material heats up, the atoms and molecules start to collide with higher kinetic energies, thus in a given time frame more collisions occur. We can roughly treat each collision as an emission of a single photon. Therefore the rate of collisions is the rate of photon emission.
By areal density, I am assuming you mean the number of photons per unit area perpendicular to the radial emission (photon's travel path). We can then say that the areal density of of photons is roughly the number of collisions happening per unit area. Then no matter the temperature of the material, the areal density will remain constant - since the number of atoms, thus the number of collisions is constant.
So, at low temperatures the emission rate decreases, but the number of photons per emission (if it makes sense) remains constant.
@Jilang, according to Nosebgr, depending on the system's dynamics, the areal density can be constant.
Planck' law says that the higher the temperature of the body the more radiation it emits at every wavelength. There is one photon for each emission. The rate of emission therefore cannot be constant.
Nosebgr didn't say that it was constant.
I read his penultimate paragraph to say that the number of collisions was constant and the number of emissions was constant. The final paragraph seemed to contradict this though. Perhaps he can clarify this.
FAQ: Photon Interval vs Areal Density for Changing Intensity
What is a photon interval?
A photon interval is the time interval between the emission and absorption of a photon.
How is photon interval related to areal density?
Photon interval is inversely proportional to areal density, which means as areal density increases, the photon interval decreases.
What is the significance of changing intensity in the context of photon interval vs areal density?
Changing intensity refers to altering the number of photons emitted or absorbed within a given time interval. This can affect both the photon interval and areal density, as a higher intensity can result in a shorter photon interval and a higher areal density.
How does the relationship between photon interval and areal density impact light absorption and emission processes?
The relationship between photon interval and areal density plays a crucial role in light absorption and emission processes. A shorter photon interval and higher areal density can lead to more efficient absorption and emission of light, while a longer photon interval and lower areal density may result in less efficient processes.
What are some practical applications of understanding photon interval vs areal density for changing intensity?
Understanding this relationship can be useful in various fields such as optics, photonics, and solar energy. It can also help in developing more efficient electronic devices, such as photovoltaic cells, that rely on light absorption and emission processes.
