Physics - Polar Coordinates: Describe the locus of points
In summary, the conversation is about a question in physics summer work regarding polar coordinate points and their locus. The question asks for the locus of points for which r = 4 and r = a. The image shown for reference is a circle with center (0,0) and radius 4. The conversation then moves on to another question with an image for reference, which is a line with a fixed angle of theta = 60 and another angle, theta1. The expert summarizes that the locus of points for this question is a straight line.
bobraymund
27
Hi,
So, I was doing my physics summer work and had no idea what the following question was talking about:
For the following polar coordinate points:
(4, 0) (4, 60) (4, 90) (4, 135) (4, 180) (4, 270)
Describe the locus of points for which
a) r = 4
b) r = a
An image, for reference, can be seen http://img43.imageshack.us/img43/6422/0815002025.jpg .
I was thinking that the answer would be merely saying something like (4, 0) (4, 60) (4, 90) (4, 135) (4, 180) (4, 270), because those are all the points at r = 4. But I have no idea. :(
Thanks for the help!
The locus of the points is a circle with center (0, 0) and radius 4.
Ah, thanks! that makes sense!
So, then this one here: http://img413.imageshack.us/img413/6007/0815002113.jpg
Would that be a line with like slope ?
Edit: the second question states: describe the locus of points for which theta = 60 and theta = theta1 (where theta1 is a fixed angle)
Yes. It is a straight line.
Hi there,
Don't worry, polar coordinates can be a bit confusing at first. To answer your question, the locus of points for which r = 4 is a circle with radius 4 centered at the origin (0,0). This is because in polar coordinates, r represents the distance from the origin to a point, and when r is constant, it creates a circle. So, in this case, the points (4, 0), (4, 60), (4, 90), (4, 135), (4, 180), and (4, 270) all lie on a circle with radius 4 centered at the origin.
For the second part, where r = a, the locus of points would be a circle with radius a centered at the origin. This is because a is a variable, so the circle could have any radius depending on the value of a. Again, the points (4, 0), (4, 60), (4, 90), (4, 135), (4, 180), and (4, 270) would all lie on this circle, but it could have a different radius than the one in the first part.
I hope that helps clarify things for you. Keep up the good work with your summer physics work!
FAQ: Physics - Polar Coordinates: Describe the locus of points
What are polar coordinates?
Polar coordinates are a way of representing points in a two-dimensional space using a distance from the origin and an angle from a reference direction.
How are polar coordinates different from Cartesian coordinates?
Polar coordinates use distance and angle to locate a point, while Cartesian coordinates use x and y coordinates.
What is the locus of points in polar coordinates?
The locus of points in polar coordinates is a curve that is formed by all the points that have the same distance from the origin and the same angle from the reference direction.
How do you graph a point in polar coordinates?
To graph a point in polar coordinates, you start at the origin and draw a line at the specified angle. Then, you measure the distance from the origin along that line to plot the point.
What are some real-life applications of polar coordinates?
Polar coordinates are used in various fields, such as navigation, physics, and engineering. They are particularly useful for representing circular or rotational movements, making them applicable in astronomy, robotics, and mechanics.
