Plastically Deformed Steel Tube - Radius of Curvature to Straighten
In summary, The question is how to straighten a bent hydraulic steel tube with a diameter of 10mm and wall thickness of 1.5mm and a bent radius of 100mm. The solution involves finding the reverse radius of curvature to apply to the tube, taking into account the Bauschinger effect and plastic deformation. A simplistic approach is acceptable, and it may involve adding a curvature (κ2) to the current curvature (κ1) to achieve a straightened tube. The load has been removed from the tube, and the method may involve calculating the strain and stress required for plastic deformation.
tr450
A hydraulic steel tube of diameter 10mm and wall thickness 1.5mm has been bent to a radius of 100mm. Calculate the reverse radius of curvature that needs to be applied to straighten the tube.
M/I= σ/Y = E/R
I am really struggling on the above question. I think I need to read off the stress/strain graph for steel to try and work the formula backwards. I believe that the material will also see the Bauschinger effect which will further complicate the working?
Any help would be greatly appreciated.
Hi,
I'd be really grateful if anyone could help with the above as I'm really struggling. Any help would be really appreciated.
Cheers.
To try and better explain the question I believe the only way to straighten the tube will be to apply a reverse bending moment at each end of the tube. As the tube has yielded and undergone plastic deformation then the only way to straighten this will be to 'overbend' it past straight; otherwise it it will elastically spring back to a slightly less radius of curvature (assuming that it has started to see plastic deformation).
What I need to do is find away of ascertaining the amount I need to overbend it by. If I work out the strain required to straighten the beam then what needs to deternmined is by how much the strain needs to be exceeded by to achieve a straightened tube. Is this the correct way of looking at it?
tr450: Do you think a simplistic approach would be acceptable? You have the curvature (κ1) to bend the tube to a straight position (while load is still applied, not yet released). Hint 1: Do you think you should add to this the curvature (κ2) corresponding to ____?
Or do you think the first sentence of the problem statement might mean the applied load currently bending the tube is still being applied right now, and not released yet?
nvn - I think a simplistic approach is definitely okay as a starting point, I can always try and expand on whatever I come up with initially. To confirm, the load has been removed from the tube.
If I can work out the curvature k2 to add onto the 100mm radius k1 then this would be the way to go. If I work out the strain on the inner radius of the tube and then ascertain the stress from the youngs modulus I will be able to check to see if it has plastically deformed again. If not then I can work out the stress needed to reach plastic deformation and from that get the radius k2. Do you think this would be the correct way of looking at it?
tr450: I am currently thinking that is perhaps sounding OK.
By the way, see item 2 in post 3940543.
FAQ: Plastically Deformed Steel Tube - Radius of Curvature to Straighten
What is plastically deformed steel tube?
Plastically deformed steel tube is a type of metal tubing that has undergone permanent deformation through the application of stress or force. This process alters the structure of the steel, making it more malleable and easier to shape.
How is the radius of curvature used to straighten plastically deformed steel tube?
The radius of curvature is a measurement of how curved the steel tube is. In order to straighten a plastically deformed steel tube, the radius of curvature is used to determine the amount of force and direction needed to reshape the tube back to its original form.
Why is it important to know the radius of curvature when straightening plastically deformed steel tube?
Knowing the radius of curvature is crucial in determining the proper method and amount of force needed to straighten plastically deformed steel tube. Applying too much force or in the wrong direction can cause further damage to the tube and affect its structural integrity.
What factors can affect the radius of curvature in plastically deformed steel tube?
The radius of curvature in plastically deformed steel tube can be affected by the amount and direction of force applied during the deformation process, the type and quality of the steel, and any external factors such as heat or pressure.
Are there any risks associated with straightening plastically deformed steel tube?
There are potential risks involved in straightening plastically deformed steel tube, such as cracking, fracturing, or weakening the tube's structure. It is important to follow proper procedures and use appropriate equipment to minimize these risks and ensure the safety and quality of the steel tube.
