Potential energy of earth and gravity
In summary, the conversation discusses the calculation of potential energy for a mass placed at a height of R from Earth's surface. The person calculates the potential energy to be mgR/4, but their teacher says it is mgR/2. The discrepancy is due to different assumptions about the reference point for zero potential energy.
Bandarigoda
36
Assume Earth's radius R and there is a mass m. We put that mass in height of R from the Earth's surface. I want to calculate it's potential energy.
I calculated it and got mgR/4 but my teacher said the answer is mgR/2 . Why my answer is wrong?
I just calculated the gravity in the height of R and applied it to e = mgh
Hi Bandarigoda! :smile:
?? :confused:
Show us your full calculations. :smile:
(and at that distance you can't treat gravity as constant)
Either answer can be right or wrong, depending on where the potential energy is supposed to be zero. Unless you fix that, the discussion is meaningless.
Here
You are assuming zero potential energy at the surface of Earth while your teacher's doing it at infinity. Both answers are correct but at these distances infinity is usually used.
Your teacher is using the formula:
$$U= \frac {Gm_1m_2}{R}$$ [edited]
Assuming U=0 at R=##\infty##
ahhh now i understand …
you've correctly found the different values of g(r) (as a function of radial distance r),
but then you've used mgh (= mg(r - R)) for potential energy,
instead of -MmG/r :wink:
Oh thank you very much guys. I got it now.
$$U= \frac {Gm_1m_2}{R^2}$$
for the record: that should be
##U= -\frac {Gm_1m_2}{R}## :wink:
Uncaffeinated brain fart.
:redface:
FAQ: Potential energy of earth and gravity
What is potential energy of earth and gravity?
The potential energy of earth and gravity is the amount of energy that an object possesses due to its position and mass in relation to the earth's gravitational field.
How is potential energy of earth and gravity calculated?
The potential energy of earth and gravity can be calculated using the equation PE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height or distance from the object to the earth's surface.
What is the relationship between potential energy of earth and gravity?
The potential energy of earth and gravity are directly proportional. This means that as the mass or height of an object increases, its potential energy also increases.
How does potential energy of earth and gravity affect objects?
Potential energy of earth and gravity affect objects by causing them to accelerate towards the earth's surface. The higher the potential energy, the greater the force of gravity and the faster the object will fall towards the earth.
Can potential energy of earth and gravity be converted into other forms of energy?
Yes, potential energy of earth and gravity can be converted into other forms of energy, such as kinetic energy, when an object starts to move due to the force of gravity. It can also be converted into other forms of energy, such as electrical energy, through systems like hydroelectric power plants.
