Power, voltage and current gain
In summary, the formula G_P (dB) = G_V (dB) + G_I (dB) assumes that the input and output impedances are equal. However, in your example, the input and output impedances are different, resulting in a different power gain calculation.
Bromio
62
Hi.
I know [itex]G_P (dB) = 10log(G_P)[/itex] and [itex]G_V (dB) = 20log(G_V)[/itex] and [itex]G_I (dB) = 20log(G_I)[/itex].
I also know that [itex]G_P (dB) = G_V (dB) + G_I (dB)[/itex].
So, if I have a common base amplifier whose current gain is [itex]G_I (dB) = 0[/itex], then [itex]G_P (dB) = G_V(dB)[/itex].
Suppose
[itex]G_V (dB) = 20 dB[/itex]. So [itex]G_V = 10^{20/20} = 10[/itex]
[itex]G_I (dB) = 0 dB[/itex]. So [itex]G_I = 10^{0/20} = 1[/itex]
As I've written above, then [itex]G_P (dB)= G_V (dB) = 20 dB[/itex]. So [itex]G_P = 10^{20/10} = 100[/itex].
But, in linear scale (not in dB), [itex]G_P = G_V\cdot G_I[/itex], so [itex]G_P = 10\cdot 1 = 10[/itex], which is not [itex]100[/itex].
What's wrong?
Thanks!
Bromio said:
Hi.
Suppose
What's wrong?
Thanks!
Where did your expressions 10^(20/20) come from? That is not part of the definition of dB, AFAIK.
Thank you for answering.
They come from [itex]G_V (dB) = 20log(G_V)[/itex]. If [itex]G_V(dB)= 20 dB[/itex], then [itex]G_V = 10^{G_V(dB)/20} = 10^{20/20} = 10[/itex], isn't it?
The voltage gain formula GV(dB)=20log(GV) assumes the input and output impedances are the same. If the impedances are the same, then a 10 times increase in voltage will result in a 10 times increase in current and 10 x 10 = 100. In your example you specify a current gain of 1 or 0dB. The requires that the output impedance be 10 times that of the input. That increase in impedance reduces the power gain to 10.
I don't understand it.
Isn't the formula [itex]G_P (dB) = G_V (dB) + G_I (dB)[/itex] always valid?
No, it's only valid if the input and output impedances are the same. Your example proves it's not valid if the impedances are different.
FAQ: Power, voltage and current gain
What is power gain and how is it calculated?
Power gain is the ratio of output power to input power in a system. It is calculated using the formula:
Power gain = Output power / Input power
How is voltage gain different from power gain?
Voltage gain is the ratio of output voltage to input voltage in a system. It is different from power gain, which takes into account the amount of power being used in the system instead of just the voltage.
What is current gain and why is it important?
Current gain is the ratio of output current to input current in a system. It is important because it allows us to amplify a small input current to a larger output current, which is necessary for many electronic devices to function properly.
What are some factors that can affect power, voltage, and current gain?
The type of components used in a system, such as resistors and transistors, can affect power, voltage, and current gain. The design and configuration of the circuit can also play a role, as well as external factors such as temperature and interference.
How can we increase power, voltage, and current gain in a system?
To increase power gain, we can use amplifiers or transformers to boost the output power. To increase voltage gain, we can use voltage amplifiers or change the voltage ratio in the circuit. To increase current gain, we can use transistors or other components that can amplify current.
