Practical on determinig if a burette is more accurate
  • Thread starter lionely
  • Tags
    Practical
In summary, the practical showed that a burette is more accurate than a measuring cylinder when measuring water volume. The first graph showed that the gradients for the burettes were closer, so the burette was said to be more accurate. The second graph showed how the volume of water delivered and collected by the cylinder were the same when the drops were uniform. The last graph showed that the volume of water delivered was the same as the volume of water collected when the drops were not uniform.
lionely
576
Practical on determining if a burette is more accurate than a measuring cylinder
Method: The burette was filled to a mark above 45cm3 with water and the reading recorded. The burette was opened and 30 drops of water were allowed to be delivered into the measuring cylinder, and the reading on the burette recorded. The volume of water in the measuring cylinder was recorded. The readings were recorded to two decimal places, these steps were then repeated allowing 60,90,120 and 150 drops of water to be delivered and the results tabulated.
Now I was asked to plot three graphs
i) Volume of liquid delivered from burette vs # of drops and Volume of liquid collected by cylinder vs # of drops on the same graph leaf.
ii) A graph of burette volume delivered Vs Volume of liquid collected in cylinder.
I don't see the point of the third graph, what's the point of plotting the volume of water delivered vs the volume of liquid collected? Could someone please explain this to me?
Oh and for the first graph , I took two gradients for each line, and compare how they close they were. For the burette I got .046cm3 and .047cm3 and for the cylinder .049 and 0.040. So since the gradients for the burettes were closer it should be more accurate right? Oh and the reason why my measuring cylinder gradient is so messed up is due to errors, in doing the experiment my partner was impatient so the rate at which the drops fell from the burette were not constant.
If the devices were perfect the two volumes should be identical ... but this graph will highlight any discrepancy.
You mean by taking the gradient it should come to say.. 1? But if it doesn't how does it show which is more accurate , i don't get it :S
If the graph is perfectly linear there may not be a way to tell - but for your lab report you must carry out an analysis of the actual data.
Data is king!
So I wasn't supposed to draw a line of best fit for the 3rd graph?
I would just plot the points ... the best fit line may be interesting, so also calculate the R^2 for it.
Then write study it and decide what it means. Good luck!
Umm What is the R^2, I'm only in grade 13, I haven't done any labs needing R^2 before, and I don't recall seeing anything like this in maths.
The least squares best linear fit will calclate a correlation coefficient called R^2. If not, forget it.
Okay just to be clear, I shouldn't think about the R^2 value and for the graph of the volumes of the drops against each other, should I just find the gradient? If the gradient is almost the same that should indicate the precision to which the experiment was carried out with? I'm still a bit lost with what to do with the third graph!
I would say the first two graphs are capable of telling you whether the drops are uniform (same volume/drop) so look for any trends in the graph like systematic slight curvature. Though if there is any that could have more than one explanation!
The last graph just compares now well the two devices give the same result. Notice any drop size variation is canceled out. So although in theory the information is all in the first two graphs, something is visible in the third one that is less evident than in the first two.
Maybe you thought they were looking for something more clever that stopped you having these simple thoughts?
One mistake students of experimental sciences make is to think of the procedures as rituals, that if you are terribly careful about the procedures and careful exact right volumes or number of drops or whatever that guarantees you truth and success. Instead they need to learn to think about validation. What really guarantees that this and that experiment or measurement is telling me what I think/they me what I think it tells? That my instruments are telling me the truth, if if necessary what do I have to do to know this? Maybe they are trying to put over this idea.
You might or you might not be able to say something (which you pretty well guess anyway) about which device is better or worse that the other and in what way. How would you decide how good either of these devices are anyway?
I hope this compensates you a bit for such a dull experiment! :biggrin:
FAQ: Practical on determinig if a burette is more accurate
What is the purpose of determining the accuracy of a burette?
The purpose of determining the accuracy of a burette is to ensure that the instrument is providing precise and reliable measurements. This is important in scientific experiments and processes where accurate volumes are crucial.
2. How do you determine the accuracy of a burette?
To determine the accuracy of a burette, you can perform a simple calibration test. This involves measuring the volume of liquid dispensed by the burette and comparing it to the known volume. The difference between the two values will give you an indication of the accuracy of the burette.
3. What is the acceptable level of accuracy for a burette?
The acceptable level of accuracy for a burette can vary depending on the specific experiment or process. However, in general, a burette with an accuracy of ±0.05 mL or better is considered to be highly accurate.
4. Can temperature affect the accuracy of a burette?
Yes, temperature can affect the accuracy of a burette. This is because temperature changes can cause the volume of the liquid to expand or contract, resulting in incorrect volume measurements. It is important to keep the temperature of the liquid and the burette constant during measurements.
5. How often should a burette be calibrated?
The frequency of calibration for a burette will depend on the frequency of use and the level of accuracy required. In general, it is recommended to calibrate a burette at least once a month or before each use if it is used frequently. If the accuracy of the burette is critical, it may need to be calibrated more often.
