Probability of logic relationships
In summary, the conversation discusses a problem in genomics where the number of unique permutations of two vectors with zeros and ones is being calculated. The goal is to find a general formula to determine the number of permutations that have at least the same number of "true" relationships as the original comparison. The conversation includes an example of a table representing genes in different genomes and their logical relationships, and the difficulty in finding a solution analytically when dealing with large data sets. The conversation also mentions the importance of the logical connector used and the goal of finding a formula for any logical connector.
riccardo
After much thinking I am trying to get a help from the board. Sorry for being naïve and thank you in advance for your answers.
Suppose you have to arrays made up of zeros and ones
a=(1,1,0,1,0,0)
b=(1,0,0,1,1,0)
and a logic relationship to compare the elements of the two arrays in a ordered way, for instance
a[0] & b[0] =true, a[1] & b[1] = true ... a[n] & b[n] = false
I would like to known a general formula to calculate the number of unique permutations of a having at least the same number of 'true' relationships as observed in the original comparison.
I know the number of the positions that became 'true' or 'false' when a '0' is replaced by a '1' or vice versa.
Riccardo
If all the relations are of the form "a(k) & b(k) = x_k", where x is either true or false, then you have y_1 * y_2 * ... * y_n possibilities, where y_k is 1 when x_k is true and 3 when x_k is false. (That's 3^a, where a is the number of times "false" appears.)
Otherwise, for each k, determine how many solutions there are, and multiply these up.
In fact all the relations are of the form "a(k) & b(k) = x_k", where x is either true or false. An example using the logical connector AND would be
AND
a b
1 1=T
0 0=F
1 0=F
1 1=T
0 1=F
Here the number of different permutations of "a" is 5!/(3!2!) and the number of permutations giving at least two "T" is 7.
I can not obtain the same result with your formula (If I understand it well).
We're clearly solving different problems. What does your table mean? It's not at all clear to me. The problem I solved would expect a string of Ts and Fs, no associated 0s and 1s.
CRGreathouse said:
What does your table mean? It's not at all clear to me. .
I will try to explain my problem better. I am carrying out research in genomics by analysing the logical relationships of genes in different genomes (i.e. organisms). In the following table
riccardo said:
AND
a b
1 1=T
0 0=F
1 0=F
1 1=T
0 1=F
columns represent two genes (“a”, “b”); rows represent genomes;
“1” indicates that the gene is present in a given genome,
“0” indicates that the given gene is absent.
When logical connector (AND in this case) is applied to the elements of the two vectors, row by row, a certain number of “true” or “false“ relationship is obtained.
What I would like to be able to count is the number of different permutations of the zeros and ones present in “a”, given “b” (or alternatively in “b”, given “a”) that give the at least the same number of “true” relationships as those observed. Comparing this number with the total number of permutations can be useful to distinguish between relationships arising by chance and actual relationships among genes.
In this particular case I can generate all possible permutations of “a” and see that there are 7 permutations that gives at least two “true” over a total of 5!/(3!2!) = 10 permutations. In my actual data set, however, it is hard to find a solution analytically because the number of elements of “a” is 140 and the permutations to be examined around 10^33.
I think that it should be possible to have formula to compute the number of permutations that can give an equal or greater number of true relationships as those observed, by knowing the number of the positions that can give “true” or “false” when a “0” is replaced by a “1” or vice versa.
Interesting, my (second) job is for a DNA microanalysis company at a university. It seems this should be related to the genomics you mention.
Still not getting it. Your table says: "a present, b present" = true; "a absent, b absent" = false; "a present, b absent" = false; "a present, b present" = true; "a absent, b present" = false.
Now I don't understand what the rows represent, properly. Are all of these to hold for one gene sequence, at the same time? That would give only one possibility ("ab"), not the 7 you have. Does each row have its own "a" and "b"? This would give 27 possibilities:
ab/ab/ab/ab/ab
ab/ab/ab/ab/a_
ab/ab/ab/ab/__
ab/a_/ab/ab/ab
ab/a_/ab/ab/a_
ab/a_/ab/ab/__
ab/_b/ab/ab/ab
ab/_b/ab/ab/a_
ab/_b/ab/ab/__
ab/ab/_b/ab/ab
ab/ab/_b/ab/a_
ab/ab/_b/ab/__
ab/a_/_b/ab/ab
ab/a_/_b/ab/a_
ab/a_/_b/ab/__
ab/_b/_b/ab/ab
ab/_b/_b/ab/a_
ab/_b/_b/ab/__
ab/ab/__/ab/ab
ab/ab/__/ab/a_
ab/ab/__/ab/__
ab/a_/__/ab/ab
ab/a_/__/ab/a_
ab/a_/__/ab/__
ab/_b/__/ab/ab
ab/_b/__/ab/a_
ab/_b/__/ab/__
where the two characters between each set of slashes is its own row and a letterwritten is present, an underscore is absent.
Rows represent organisms, the order of which is kept constant in the comparison. So for example in the first row, organism 1 has the gene "a" and the gene "b", in the second row organism 2 don't have the genes "a" and "b", in the tirth row organism 3 has the gene "a" but not the gene "b" and so on. Obviously genes "a" (and "b") have different sequences in different organisms but we have reasons to believe that they represent the same gene with the same function.
The particular logical connector used here is not very important. I would to try with all possible logical connectors. The important thing for me is, once a particular result is observed (as for example two "true" relationship as in the case above), to know how "surprising" is that result. For that I would like to permute the order of the "1" and "0" of gene "a" across the column (that is equivalent to change the distribution of gene "a" across the organisms) and to count how many permutations over the total give the same or a better result. The kind of permutation which I am referring to are:
a b
1 1=T / 1 1=T / 1 1=T / 1 1=T / 1 1=T / 1 1=T / 0 1=F / 0 1=F / 0 1=F / 0 1=F /
0 0=F / 0 0=F / 0 0=F / 1 0=F / 1 0=F / 1 0=F / 1 0=F / 1 0=F / 1 0=F / 0 0=F /
1 0=F / 1 0=F / 0 0=F / 0 0=F / 0 0=F / 1 0=F / 1 0=F / 1 0=F / 0 0=F / 1 0=F /
1 1=T / 0 1=F / 1 1=T / 1 1=T / 0 1=F / 0 1=F / 1 1=T / 0 1=F / 1 1=T / 1 1=T /
0 1=F / 1 1=T / 1 1=T / 0 1=F / 1 1=T / 0 1=F / 0 1=F / 1 1=T / 1 1=T / 1 1=T /
As you can see there are 10 different permutation of "a" ("b" is kept fixed), with 7 permutations giving at least two true relationships. Riccardo
FAQ: Probability of logic relationships
What is the definition of probability in logic relationships?
The probability of a logic relationship refers to the likelihood or chance of a statement or event being true or occurring based on the available evidence or information.
How is probability calculated in logic relationships?
In logic relationships, probability is calculated by dividing the number of possible outcomes that satisfy a given condition by the total number of possible outcomes.
What is the difference between conditional and unconditional probability in logic relationships?
Conditional probability in logic relationships refers to the probability of an event occurring given that another event has already occurred. Unconditional probability, on the other hand, refers to the probability of an event occurring without any conditions or prior knowledge.
How does the concept of probability apply to logical reasoning and decision making?
The concept of probability is essential in logical reasoning and decision making as it allows us to make informed judgments and predictions based on the available evidence. Probability helps us to assess the likelihood of different outcomes and make decisions based on the most probable outcome.
Can probability be used to prove or disprove a logical statement?
No, probability cannot be used to prove or disprove a logical statement. Probability only provides an estimation of likelihood based on available evidence and does not guarantee the truth or falsity of a statement.
