Problem Solving with Probability
Thus, we should divide our sum by 2, as there are two ways to select 5 letters from BOOKKEEPER. If this is unclear, I'd be happy to try to clarify it further.In summary, the number of ways to arrange the letters in the word BOOKKEEPER is 151200. The number of ways to arrange the letters in the word BOOKKEEPER if you select at most 3 is 30. The number of ways to arrange the letters in the word BOOKKEEPER if you select only 5 is 1260.
Raza
203
Hi, I just need people to check my work.
1.
a) Determine the number of ways to arrange the letters in the word BOOKKEEPER.
I did [tex]\frac{10!}{2!2!3!}[/tex]
which is 151200.
b) Determine the number of ways to arrange the letters in the word BOOKKEEPER if you select at most 3.
I did [tex]\frac{10P_3}{2!2!3!}[/tex]
which is 30.
c) Determine the number of ways to arrange the letters in the word BOOKKEEPER if you select only 5.
I did [tex]\frac{10C_5}{2!2!3!}[/tex]
which is 10.5.
I know c) can't be a decimel.
for part a),
How many distinct letters make up the word BOOKEEPER?
What is the repetition number of each letter?
You have the following letters:
1 B
2 Os
1 K
3 Es
1 R
So you can rearrange the Os and the Es. There are Two ways to rearrange the Os and Six ways to rearrange the Es. and 2 * 6 is 12. Is that not right?
Do you have to spell Bookeeper or can they be in any order?
There are 6 distinct letters make up the word BOOKEEPER and the repetition number of each letter are lised below.
B O K E P R
1 2 1 3 1 1
I don't see how this helps me answer the question though.
EDIT:Oh, I made a mistake there, I don't know why I had another 2!. I just edited my work, is it alright now?
how did you come up with 10! in the numerator?
(how many letters are in the word BOOKEEPER ?)
1 B
2 Os
1 K
3 Es
1 R
The question asks to count the number of distinct arrangments of the word BOOKEEPER.
So for example one such arrangement is OEBEPKORE and another is ROOKEEPEB.
Notice if we swap the positions of the O's in the last example we obtain the same arrangement as before. This is because the O's are considered indestinguishable, we can not tell one O from the other. Same thing with the E's.
Oh, the reason why I had 10! and another 2! was because it was suppose to spell BOOKKEEPER with 2 K's. I was addled with the lettering of the word.
EDIT:
I just changed it, is c) correct?
EDIT:
Ok, adding that extra K makes your original answer to part (a) correct. As its written now though, you forgot to edit back in the extra factor of 2! in the denominator. Obviously I didn't know how to spell BOOKKEEPER either :biggrin:
I would do (c) first, and then use similar methods to solve (b).
Obviously, as you stated, part (c) is incorrect as the answer can not be rational.
suppose we want to calculate the number of arrangements of BOOKE, then using the methods from part (a), we get that this equals,
[tex] \frac{5!}{2!} = 60[/tex]
now let's do the same for BOOEE, we get
[tex] \frac{5!}{2!2!} = 30 [/tex]
To get all possible arrangements of size 5 from the word BOOKKEEPER, we must perform this calculation for each of the possible ways of selecting 5 letters from BOOKKEEPER, and add our results. Also keep in mind that BOOKE (selecting the first K and third E), is the same as BOOKE (selecting the second K and first E) because the K's and E's are indestinguishable.
FAQ: Problem Solving with Probability
What is probability and why is it important in problem solving?
Probability is the measure of the likelihood of an event occurring. It is important in problem solving because it allows us to make predictions and decisions based on the likelihood of different outcomes. It helps us understand and analyze uncertainties in situations, making it a valuable tool for decision making.
What are the different types of probability?
The three main types of probability are theoretical, experimental, and subjective. Theoretical probability is based on mathematical calculations and theoretical models. Experimental probability is based on data collected through experiments or observations. Subjective probability is based on personal beliefs and judgments.
How do you calculate probability?
To calculate probability, you divide the number of favorable outcomes by the total number of possible outcomes. This is known as the probability formula: P(event) = number of favorable outcomes / total number of possible outcomes. It is important to note that the total number of possible outcomes must be equally likely to occur.
How can probability be used to solve real-world problems?
Probability can be used to solve real-world problems in various fields such as finance, science, and business. For example, it can be used in risk assessment to determine the likelihood of certain events occurring and make decisions accordingly. It can also be used in data analysis to make predictions and identify patterns.
What are some common misconceptions about probability?
One common misconception about probability is that it predicts the outcome of a single event. In reality, probability is used to predict the likelihood of an event occurring over a large number of trials. Another misconception is that past events can influence future outcomes. In reality, the outcome of a random event is not affected by previous outcomes. Lastly, people often confuse probability with certainty, thinking that if an event has a high probability, it will definitely happen. However, probability only tells us the likelihood of an event occurring, not the certainty of it.
