Projectile Motion Question (physics 101)
In summary: But apparently not. You're right. I need to find the time first. Thanks for the help!In summary, a projectile is shot from a cliff with an initial speed of 65.0 m/s at an angle of 37 degrees with the horizontal. Its horizontal and vertical components of velocity are found at the instant just before it hits the ground.
cheese89
A projectile is shot from the edge of a cliff 125 m above ground level with an initial speed of 65.0 m/s at an angle of 37 degrrees with the horizontal. Find the horizontal and vertical components of its velocity at the instant just before the projectile hits point P (the ground).
Vxo = Vo cos 37
Vyo = Vo sin 37
Vy = Vyo - gt ...?
The answer is given in the back of the book. Plugging in the initial velocity in the first equation gives the correct answer (which I expected), but the answer I achieve for Vyo should be negative and I haven't yet acheived that. I tried to plug the answer I got for Vyo (the positive one) into the equation Vy = Vyo - gt, but still did not get the right answer. I'm truly grasping at straws here.
You can use Vy = Vyo - gt to find the vertical component, but must first find the time at which the projectile reaches P. To do this, you use the equation for the y-coordinate as a function of time.
cheese89 said:
Vxo = Vo cos 37
Vyo = Vo sin 37
Vy = Vyo - gt ...?
Hi cheese89! :smile:
I don't understand how you got any result for Vy from Vy = Vyo - gt … :confused:
you don't know what t is.
Hint: you haven't used y = 125 yet, have you? :wink:
Vxo = Vo cos 37
Vyo = Vo sin 37
Vy = Vyo - gt ...?
Its an oral question dear. Just think will the boy acclerate in x direction. If it does, vertical component will change otherwise not. For the y direction, whatever you throw come down with same speed.
For this problem you should check your constant acceleration formulas. The Acceleration in this case is a constant -9.8m/s^2(gravity). And there is no acceleration in the x direction. The velocity would be v=Vo+at. where v= final velocity, Vo= initial velocity, a=acceleration, and t= time. Look at the information given to you in the problem and consult some of the other formulas. You have a displacement of 125m, a Vo, the acceleration, the angle. all you need is the time it took to get to the ground and you will have your answer =)
Hi ritwik06! :smile:
That only applies when we throw from the ground … this is from a 125 m cliff. :wink:
you have to find time first using the formula Y = vt + 1/2 g t^2
I know. I thought cheese was working for that interval as well.
FAQ: Projectile Motion Question (physics 101)
What is projectile motion?
Projectile motion is the motion of an object through the air or space under the influence of gravity. This type of motion follows a curved path known as a parabola.
What factors affect projectile motion?
The factors that affect projectile motion include initial velocity, angle of launch, air resistance, and gravity.
How do you calculate the range of a projectile?
The range of a projectile can be calculated using the formula: R = (v^2 * sin2θ)/g, where R is the range, v is the initial velocity, θ is the angle of launch, and g is the acceleration due to gravity.
What is the difference between horizontal and vertical components of projectile motion?
The horizontal component of projectile motion refers to the motion of an object along the x-axis, while the vertical component refers to the motion along the y-axis. These components are independent of each other, meaning the vertical motion is affected by gravity, while the horizontal motion remains constant unless acted upon by an external force.
How does the angle of launch affect projectile motion?
The angle of launch affects the range and height of a projectile. A larger angle will result in a longer range, while a smaller angle will result in a higher peak height. The optimal angle for maximum range is 45 degrees.
