Proof f(x)>g(x) in an interval
In summary: I'm not sure what you're trying to say here. Are you having trouble starting the proof? Have you thought about using the Mean Value Theorem, as I suggested?I'm not sure what you're trying to say here. Are you having trouble starting the proof? Have you thought about using the Mean Value Theorem, as I suggested?In summary, the conversation discusses a proof involving continuous and differentiable functions in a given interval. The participants discuss using the Mean Value Theorem and proving that a particular function is always positive. They also mention the importance of being precise and thinking mathematically in approaching the problem.
Dank2
213
let fx, gx be continuous in [a,b] and differentiable in (a,b). at the end of the interval f(a) >= g(a).
and f'(x) >g'(x) for a<x<b.
proof f(x) > g(x) for a<x<=b
Attempt:
There is a statement says that if the f'x = g'x for x in [a,b] , then there exists k such that f'x - g'x = k for any x in [a,b]
but f'(x) = g'(x) + t(x), where t(x) isn't have to be a line. and i cannot use the statement
Dank2 said:
and f'(x) > g'(x) for a<x<b.
Shouldn't that be a < sign ?
nope.
Might be hard to prove, then:
a=0, b =2, f(x) = x, g(x) = 1 satisifies all criteria, yet f < g on half the interval.
[edit] Ah, the end of the interval is at the beginning. My bad o:) :rolleyes:
but f(a) is not equal or or bigger thatn g(a).
Yeeah, I get it. Was wrongfooted by the 'end' term.
With f' - g' > 0 and the definition of derivative you should be able to go through the interval without f-g diminishing from its starting value f(a)-g(a).
Likes Dank2
f'(x) - g'(x) = lim(f(x+h) -f(x) -g(x+h) -g(x))/h > 0
like that? how can i take out f(x) - g(x)
Ergo there is a h> 0 such that f(a+h)-g(a+h) > f(a)-g(h)
Likes Dank2
wait but we need x no?, a is the start of the interval
So a+h is the new 'beginning' for the next step. Crux is if we can prove this can be continued all through the a,b interval in a finite number of steps.
Likes Dank2
but why doesn't the limit and the h at the denominator making problems here?
what I've got is
lim (f(x+h) - g(x+h))/h > lim (f(x) + g(x))/h
what I've got is
ok i think i got it, the limit doesn't change it much
what I've got is
I'm not sure looking at the definition of the derivative is the best way forward. In any case, it's best to introduce a new function, let's call it ##k## such that:
##k(x) = f(x) - g(x)##
What can you say about ##k##? And what theorems do you know?
Likes Dank2
it is continuous and it is differentiable.
However there is a theorem i know regarding k(x) being constant, but i cannot assume it here.
Do you know the Mean Value Theorem?
yes
Dank2 said:
yes
It might be useful here!
So;
(f(b) - f(a))/b-a > (g(b)-g(a))/b-a
and i can pick any b-a such that the diffrence is very small, so i can use x instead of it ?? so f(b) - f(a) = f(b)
Dank2 said:
So;
You need to switch your attention to ##k(x)##. Also, I suggest a proof by contradiction using the MVT.
ok K'(x) >0 for any x in the interval.
That's true. What are you trying to prove about ##k(x)##?
Likes Dank2
Thread moved from Precalc section. @Dank2, please post questions involving differentiation (and differentiable functions) in the Calculus & Beyond section.
Likes Dank2
that is always positive
You need to put a bit more effort in here! You're doing real analysis, which requires precision in terms of the statement of a problem. I'll help you on this point, but you need to start thinking more (pure) mathematically:
We have that ##k## is continuous on ##[a, b]##, differentiable on ##(a, b)##, ##k(a) \ge 0## and ##\forall x \in (a, b), \ k'(x) > 0##.
We must show that ##\forall x \in (a, b], \ k(x) > 0##
Likes BvU and Dank2
same problem as before
assume k(x) <0 for some x latter than a, then we will get at one point k'(x) = 0, since at the start of the iterval k(x) > 0 , and it is a continuous function. and that's a contradiction since k'(x) >0 for any x in the interval, and ther fore there is no point where k(x) < 0
This answer shows that you are lacking mathematical technique. In this case, you need to reserve ##x## as your variable and use, for example, ##x_0, x_1, x_2## for specific values of ##x##.
Also, I think you are confusing the Mean Value Theorem with the Intermediate value theorem. Note that we cannot assume that ##k'(x)## is a continuous function, so applying the IVT to ##k'(x)## is not possible. So, you will need to apply the MVT to ##k(x)##.
i just get
k'(c) = k(b) - k(a) = f(b)-g(b) - (f(a) - g(a)) (with b-a at the denominator)
or do i not use it right?
Dank2 said:
i just get
The MVT applies to any interval. In this case it won't be ##[a, b]##. If you find an ##x_0## such that ##k(x_0) \le 0##, then you can apply the MVT to ##[a, x_0]##.
Likes Dank2
can't see how to get the contradiction, ill work on it next time, thanks friend.
  • #31
I that supposed to be
let f(x), g(x) be continuous in [a,b] ...​
Attempt:
Did you mean that literally?
There is a statement says that if the f'x = g'x for x in [a,b] , then there exists k such that f'x - g'x = k ...​
or perhaps:
f'(x) = g'(x) for x in [a,b] , then there exists k such that f'(x) - g'(x) = k ...​
Thank you @PeroK !
FAQ: Proof f(x)>g(x) in an interval
What does it mean for f(x) to be greater than g(x) in an interval?
When we say that f(x) is greater than g(x) in an interval, it means that for all values of x within that interval, the value of f(x) is larger than the value of g(x).
How do you prove that f(x) is greater than g(x) in an interval?
To prove that f(x) is greater than g(x) in an interval, you need to show that for all values of x within that interval, the value of f(x) is greater than the value of g(x). This can be done using various methods, such as algebraic manipulation, graphical representation, or calculus techniques.
Can f(x) and g(x) be equal in an interval and still satisfy the condition f(x)>g(x)?
Yes, it is possible for f(x) and g(x) to be equal in an interval and still satisfy the condition f(x)>g(x). This can happen if both functions have the same value at the endpoints of the interval, but f(x) has a higher value than g(x) at some point within the interval.
What happens if f(x) and g(x) are not defined at some points within the interval?
If f(x) and g(x) are not defined at some points within the interval, then the condition f(x)>g(x) cannot be satisfied for those specific values of x. However, if the condition holds for all other values of x within the interval, then the statement "f(x) is greater than g(x) in the interval" still holds.
Is it possible for f(x) to be greater than g(x) in one interval and less than g(x) in another interval?
Yes, it is possible for f(x) to be greater than g(x) in one interval and less than g(x) in another interval. This can happen if the behavior of the two functions changes at the boundary between the two intervals, causing their relative values to switch.
