Prove Cyclic Factor Group of a Cyclic Group is Cyclic
  • Thread starter Fisicks
  • Tags
    Proof
In summary: H>* , which is just the product of the generators. So in summary, the factor group of a cyclic group is cyclic.
Fisicks
85
Prove that the factor group of a cyclic group is cyclic.
Now I understand introductory AA very well. But I am just having a brain fart on this problem lol.
Let G= <g> and H be a subgroup of G. Then it is true, from basically definition that G/H= <gH>.
Where the equality means they are the same set but <gH> is going to repeat some cosets most of the time. Can i conclude G/H is cyclic?
If not then I would probably say take the duplicates out, and show that <gH> (without duplicates) is a subgroup of <gH> which i could then conclude G/H is cyclic.
Hi, Fisicks:
don't mean to be pedantic, but , to make sure I understand you: you mean the
quotient group of a cyclic group G by _any_ subgroup is cyclic, right?
If so, as you said, G/H is defined to be the set {Hg: g in G} (you can select
any representative of Hg if Hg'=Hg; one can show G/H is well-defined in this
sense.) , and group operation given by: (Hg)(Hg')=Hgg' ; where gg' is the multiplication
in G.
Now, G is cyclic, so there is a g in G so that {g,g<sup>2</sup>,...,g<sup>n</sup>,..
} =G (G may be cyclic and finite too; if so, the argument is similar )
Now, consider Hg , where g is the generator of G, and consider the product:
Hg<sub>i</sub>Hg<sub>j</sub>:=Hg<sub>i</sub>g<sub>j</sub>
Can you see how to generate {Hg: g in G} this way?
Just another proof, just in case:
i) Every infinite cyclic group is isomorphic to Z, the integers. Every finite cyclic group
is isomorphic to {nZ: n an integer}. Every quotient group of a cyclic group is then
of the form:
Z/nZ:~Z/n ={1,...,n-1,n} , which is generated by 1
Proof of above assumption on form of subgroups:
Every cyclic group is countably-infinite, i.e., can be indexed by the pos. integers.
But the pos. integers are well-ordered, so that every subgroup H--as a set-- has
a least element h. By group properties, if h is in H, then so is h+h=2h, ..., so is
h+h+...+h=nh,... . So every subgroup of G is of the form H={nh: h in H}.
An adjustment can be made for finite cyclic groups, using the fact that the
order of a subgroup divides the order of the group.
And, re the cosets, there is overlap of cosets in G/H, if |H|>1 , by Lagrange's
thm: |G/H|=|G|/|H|<|G| if |H|>1 , and |G/H|=|G| only iff |H|=1
All subgroups of a cyclic
My algebra is not the strongest, so better to listen to mathwonk
look at the image of the generator.
Mathwonk, you are saying that I cannot conclude that G/H is cyclic from the fact alone that G/H and <gH> have the same elements?
So if I prove that the image of <gH> is a subgroup of <gH>, I then know that G/H is cyclic because G/H is precisely the image of <gH> and any subgroup of a cyclic group is cyclic.
I just confused myself even more. I proved that G/H= H U gH U... U g^(k-1)H. Each is distinct because each power of g is less than k. So G/H=<gH>.
Someone clear my head up please. I know this is trivial so I want to move past this lol.
I did not mean to imply i believed my answer was incorrect, only that mathwonk
is likely to be more insightful, while at my rudimentary level, I need to appeal
to the big machinery.
Anyway, a couple of comments:
1) Do a small quotient like S<sub>3</sub>/A<sub>3</sub> , to see why
you don't get all different cosets.
2)G/H={Hg: g in G} is a group * , with multiplication defined by:
(Hg)(Hg'):=(Hgg')
If g is a generator for G, then, for any w in G, there is an integer n with
g<sup>n</sup> =w
Now, can you see what you get by doing the product :
(Hg)(Hg)...(Hg) (n times)
What if you wanted to obtain the coset Hk , for some k in G. What would
you do; how would you use the generator g to do so?
* When H is normal in G, which is true in our case
FAQ: Prove Cyclic Factor Group of a Cyclic Group is Cyclic
What is a cyclic group?
A cyclic group is a mathematical structure that consists of a set of elements and an operation that can be applied to those elements. The operation combines two elements to produce a third element, and this process can be repeated to generate all the elements in the group. The defining feature of a cyclic group is that there is a single element, called the generator, that can be used to generate all the other elements in the group.
What does it mean for a group to be cyclic?
A group is considered cyclic if all of its elements can be generated by repeatedly applying the group operation to a single element, known as the generator. In other words, every element in a cyclic group can be expressed as a power of the generator.
How do you prove that a cyclic factor group is cyclic?
To prove that a cyclic factor group is cyclic, we must show that it can be generated by a single element. This can be done by showing that the factor group has a unique generator, or by demonstrating that all of its elements can be expressed as powers of a single element.
What is a cyclic factor group?
A cyclic factor group is a subgroup of a larger group that is itself cyclic. It is formed by choosing a particular element, known as the factor, and then taking all the elements in the larger group that can be formed by repeatedly applying the group operation to the factor. The resulting subgroup is called a cyclic factor group.
Why is it important to prove that a cyclic factor group is cyclic?
Proving that a cyclic factor group is cyclic is important because it allows us to better understand the structure of the larger group. It also helps us to identify key elements, such as the generator, which can be used to generate all the other elements in the group. This knowledge can then be applied to solve more complex problems and make connections to other areas of mathematics.
