phucnguyen
- 6
This is question 30, section 2.5 from "Abstract Algebra 3rd edition" by Herstein.
G is a group. Suppose that |G| = pm, where p does not divide m and p is a prime. If H is a normal subgroup of order p in G, prove that H is characteristic.
2. Relevant information
A subgroup H of group G is called characteristic if for all automorphisms phi of G, phi(H) is a subset of H.
(I paraphrased this from question 29. I don't know why he says "phi(H) is a subset of H" but not "phi(H) and H are the same set". After all, phi is bijective?)
Here is what I did:
H is a subgroup of order prime, so it is cyclic, generated by any non-identity element in H. Call H <a>.
Let phi be an arbitrary automorphism on G, then phi must map <a> to yet another cyclic subgroup of order p in G, call this <phi(a)>. Since both <a> and <phi(a)> are cyclic, they're either the same subgroup, or only share the identity element.
Let K of be the smallest subgroup generated by every possible products of <a> and <phi(a)>. If <a> and <phi(a)> are different, then the order of K is p2. So p2 has to divide pm, which contradicts the fact that p does not divide m. So <a> and <phi(a)> have to be the same subgroup in G.
Hence any automorphism phi on G will also be an automorphism on <a>, which implies that <a>, aka H, is characteristic.
My problem: I never used the fact that H is a normal subgroup. I'm being quite confused. Where was I wrong? Many thanks for the help.
