Quantum physics and equivalence principle
In summary, there are articles discussing the idea that the equivalence principle may not be valid in the realm of quantum physics, citing examples such as neutrinos changing colors and the COW experiment. However, there is no clear understanding of why this is the case. It is believed that if an experiment could be conducted to show a violation of the equivalence principle in quantum gravity, it would greatly advance our understanding of the subject. Some theories, such as string theory and supergravity, suggest that there may be violations of the equivalence principle due to the presence of light scalar fields, but there are proposed methods to mitigate these violations to below observable levels. Further explanations and links to resources on this topic would be appreciated.
exponent137
565
34
I read some articles, where equivalence principle is no more valid in quantum area. One example are neutrinos, changing colours (electron, muon, tauon neutrino). But formulae are not derived from fundaments, so I do not understand, where it is the catch.
I read also about COW experiment, this is experiment with neutrons in gravitational field. Phase difference at this experiment is dependent from neutron mass. But behavior in gravitational field should be independent from gravitational field. So, hot it is with this?
Are here any clear and simple suggestins, what should happens with equivalence principle in quantum area?
But I am aware that experiment which would violate equivalence principle because of quantum physics, will be revolutionary for quantum gravity. But now it does not exist idea, how to do some measurement in quantum gravity area.
Best regards
I will try with one more specific question: In http://en.wikipedia.org/wiki/Equivalence_principle
it is written that
"The need to continue testing Einstein's theory of gravity may seem superfluous, as the theory is elegant and is compatible with almost all observations to date (except for instance the Pioneer anomaly). However, no quantum theory of gravity is known, and most suggestions violate one of the equivalence principles at some level. String theory, supergravity and even quintessence, for example, seem to violate the weak equivalence principle because they contain many light scalar fields with long Compton wavelengths. These fields should generate fifth forces and variation of the fundamental constants. There are a number of mechanisms that have been suggested by physicists to reduce these violations of the equivalence principle to below observable levels.
Can someone explain this or find links with explanations?
I would like to address the topic of quantum physics and the equivalence principle. The equivalence principle, as stated by Albert Einstein, states that the effects of gravity are equivalent to the effects of acceleration. This principle has been a cornerstone of classical physics and has been successfully tested in a wide range of experiments. However, as you have mentioned, there have been some recent studies and experiments that suggest the equivalence principle may not hold true in the realm of quantum physics.
One example of this is the behavior of neutrinos, which have been observed to change colors as they travel through space. This phenomenon is known as neutrino oscillation and it is a clear violation of the equivalence principle. In addition, the COW experiment, which observed the phase difference of neutrons in a gravitational field, also challenges the principle as the mass of the neutron was found to affect the results.
So, why is this happening? It is important to note that the equivalence principle is a fundamental concept in classical physics but it may not hold true in the quantum realm. This is because quantum physics introduces new principles and laws that govern the behavior of particles at a subatomic level. The behavior of particles in a gravitational field may not follow the same rules as larger objects, and therefore the equivalence principle may not apply.
As you mentioned, the idea of quantum gravity is still a topic of ongoing research and there is currently no clear understanding of how to measure or test it. Any experiment that can successfully demonstrate a violation of the equivalence principle in the realm of quantum physics would be groundbreaking and could lead to a better understanding of quantum gravity.
In conclusion, while the equivalence principle has been a crucial concept in classical physics, it may not hold true in the realm of quantum physics. More research and experiments are needed to fully understand the implications of this and to develop a better understanding of quantum gravity.
FAQ: Quantum physics and equivalence principle
What is quantum physics?
Quantum physics is a branch of physics that studies the behavior and interactions of subatomic particles, such as atoms and photons, at the quantum level. It explains the fundamental principles of matter and energy and is essential to understanding the behavior of the universe at a microscopic level.
What is the equivalence principle in quantum physics?
The equivalence principle states that the effects of gravity and acceleration are indistinguishable. In other words, an observer in a uniform gravitational field will experience the same physical laws as an observer in an accelerated frame of reference. This principle is crucial in understanding the behavior of particles in a gravitational field.
How does quantum physics relate to the equivalence principle?
Quantum physics plays a significant role in understanding the equivalence principle. It helps explain the behavior of particles in a gravitational field, such as the bending of light by massive objects and the redshift of light in a gravitational field. It also provides a framework for understanding the behavior of quantum systems in the presence of gravity.
What are some applications of quantum physics and the equivalence principle?
Quantum physics and the equivalence principle have many practical applications, such as in GPS technology, where precise time measurements are needed to account for the effects of gravity on satellites. They also play a crucial role in the development of quantum computers, which use quantum effects to perform calculations much faster than classical computers.
Are there any challenges or limitations to understanding quantum physics and the equivalence principle?
Yes, there are still many unanswered questions and challenges in understanding and applying quantum physics and the equivalence principle. For example, scientists are still working to unify quantum physics with Einstein's theory of general relativity to create a complete theory of quantum gravity. Additionally, the behavior of quantum systems in extreme gravitational fields, such as black holes, is not fully understood and remains a topic of ongoing research.
9K
