Question about Archimedes Principal
  • Thread starter ZeroXD
  • Tags
    Archimedes
In summary, the conversation is about solving a homework problem regarding buoyancy. The problem involves finding the volume of a block submerged in water and alcohol, given the weight of the block in both liquids and the density of the alcohol. Archimedes' principle is mentioned, which states that an object immersed in a liquid displaces a volume of liquid equal to its own volume and its weight is reduced by the weight of the displaced liquid. The solution involves setting up equations using the weight and density of water and alcohol, and solving for the volume of the object.
ZeroXD
Hi everyone,
im having some difficulties with a certain homework problem I'm on.
Up until now I've solved all buoyancy problems knowing its weight in air and its weight submerged in a liquid (generally water).
In this particular problem, it gives the weight of the block completely submerged in water as 25 Newtons, and the weight of the blocked cmpletely submerged in alcohol as 25.7 Newtons. Then it states the density of the alcohol is 806 kg/m^3. How would I go about solving for volume of the block?
thanks in advance.
Archimedes' principal states that an object, immersed in a liquid, displaces a volume of liquid equal to its own volume and its weight is reduced by the weight of the liquid displaced.
Let W be the (weight) density of water and A the (weight) density of alcohol.
Let V be the volume of the object and G its weight.
The weight of water displaced is WV so the weight of the object in water is G- WV= 25 Newtons.
The weight of alcohol displaced is AV so the weight of the object in alcohol is G- AV= 25.7 Newtons.
Since you know both W and A, you can eliminate G from the two equations and solve for V.
Hi there,
It seems like you are having some difficulty applying Archimedes' Principle to this specific problem. Let's break it down step by step to make it easier to understand.
First, let's review Archimedes' Principle. It states that the upward buoyant force on an object submerged in a fluid is equal to the weight of the fluid that the object displaces. In other words, the weight of the fluid that is pushed aside by the object is equal to the upward force that keeps the object afloat.
Now, let's apply this principle to your problem. We know that the weight of the block submerged in water is 25 Newtons and the weight of the block submerged in alcohol is 25.7 Newtons. This means that the upward buoyant force on the block is equal to the weight of the fluid it displaces in both cases.
Next, we need to find the weight of the fluid that is displaced by the block in each case. This can be calculated by multiplying the density of the fluid by the volume of the block. In this case, the density of alcohol is given as 806 kg/m^3.
So, to solve for the volume of the block, we can set up the following equation:
Weight of block in water = Density of water x Volume of block
25 Newtons = 1000 kg/m^3 x Volume of block
Volume of block = 25 Newtons / 1000 kg/m^3 = 0.025 m^3
Similarly, for the block submerged in alcohol, we can set up the following equation:
Weight of block in alcohol = Density of alcohol x Volume of block
25.7 Newtons = 806 kg/m^3 x Volume of block
Volume of block = 25.7 Newtons / 806 kg/m^3 = 0.0319 m^3
Therefore, the volume of the block is 0.025 m^3 when submerged in water and 0.0319 m^3 when submerged in alcohol. I hope this helps you solve your homework problem. If you have any further questions, don't hesitate to ask. Best of luck!
FAQ: Question about Archimedes Principal
What is Archimedes' principle?
Archimedes' principle states that when an object is placed in a fluid, it experiences an upward force equal to the weight of the fluid it displaces.
Who was Archimedes?
Archimedes was a Greek mathematician, physicist, engineer, inventor, and astronomer who lived in the 3rd century BC. He is known for his contributions to mathematics and physics, including Archimedes' principle.
How is Archimedes' principle used in everyday life?
Archimedes' principle is used in many everyday objects and activities, such as boats, submarines, hot air balloons, and swimming. It is also used in industries such as shipbuilding, oil drilling, and underwater construction.
What is the significance of Archimedes' principle?
Archimedes' principle is significant because it explains the buoyant force and allows us to understand why objects float or sink in a fluid. It also has numerous practical applications in various fields of science and engineering.
What is the relationship between Archimedes' principle and density?
Archimedes' principle is closely related to density, as the buoyant force acting on an object is directly proportional to the density of the fluid it is placed in. This means that an object with a higher density than the fluid will sink, while an object with a lower density will float.
10K
