Question about Inverse SQRT of Amplitude
In summary: Mosely used 'K' and 'L' waves to derive atomic numbers of elements. He used these waves to measure the size and shape of atoms. He found that the atoms with the highest atomic numbers were the smallest and had the most angular shapes.
zarkorgon
Before we begin, recall the simple formulas;
for reference see http://eosweb.larc.nasa.gov/EDDOCS/wavelength.html
Velocity / Wave Length = Frequency (Hertz)
Speed of the wave = Frequency x Wavelength
Wavelength = Speed of the wave / Frequency
AND Where
TIME is the RECIPROCAL of ENERGY
as
SPACE is the RECIPROCAL of MATTER
An obvious relationship exists between time and space
So
IF A = Rife frequency (1.) and
B = Rife frequency (2.)
where both A and B are unique, individual frequencies;
if we perform the following;
C = SQRT ( A * B )
Then 'C' simply represents the root of the product of the two frequencies
HOWEVER
X = 1 / SQRT ( A * B )
Then ' X ' must actually represent some form of ENERGY domain or equivalency
BUT, if we change this scenario just slightly so that
E = Phase
where A is an individual frequency and where E is a given Phase of A;
D = ( A * E )
D = Amplitude
So
Y = 1 / SQRT ( D )
If wave length corresponds to the span of space traversed over that time period, hence the completely different units of measure used to describe each, i.e.;
And if Wave amplitude describes a span of time.
Here, then does Y equate to a SPATIAL domain or equivalency, i.e. a derivative of wavelength?! IF so what would 'Y', BE exactly!
AND Where
How did you arrive at this conclusion?
as
Likewise this one? These are your invention and have no meaning to anyone else.
A. Einstein very carefully derived a relationship, you pull it out of the air?
So
What in the world are you talking about?
C = SQRT ( A * B )
By the commonly accepted method of dimensional analysis. C is also a frequency
HOWEVER
Interesting bit of speculation, but you have pulled it out of the air. It does not follow from anything you have said.
E = Phase
D = ( A * E )
D = Amplitude
Once again you materialize a result as if it had meaning. By the commonly accepted method of dimensional analysis, I get D as radians/sec this is not normally a amplitude.
So
Y = 1 / SQRT ( D )
Lots of words but I could not find any meaningful content.
Be very careful where you take this thread.. I suspect a lock or delete is not to far off.
I vote for deletion. His other post in the particle physics forum was much more straightforward. This post of his here makes no sense, and is a waste of time to try to read and respond.
from the pl physics forum:
zarkorgon said:
Hi, I am an amateur to physics, am trying to understand what Mosely actually did when he used 'K' and 'L' waves to derive atomic numbers of elements.
Can someone please tell me what exactly the 'K' and 'L' waves are, respectively?
What is a 'K' wave and what does it measure?
What is a 'L' wave and what does it measure?
THANKS !
INTEGRAL - Regarding 1/SQRT(a*b)
Thank you very much for your timely, thoughtful and instructive response.
I am new here, I realize your patience with me and will do my very best to behave and communicate in a manner that is inline with this communitys protocols and comfort requirements.
What I expressed in my past post, I fear, was poorly described by me.
I am ignorant in a number of the areas that I seek information for. I very much appreciate any insights and constructive critiques. I can see why you felt that many of my assertions were "out of the air". I had been digesting online notes that were partially speculative in nature about these topics and I did not mention that this is where much of my statements were coming from. Apologies for the confusion.
In your last response you said something that really got my attention and it seems that you may have answered the most important part of my inquiry;
"Once again you materialize a result as if it had meaning. By the commonly accepted method of dimensional analysis, I get D as radians/sec this is not normally a amplitude."
Integral, could you please extrapolate on this? You are saying that D simply represents a value of radians per second? Anything further you feel free to share? Please note, I am simply wishing to learn...
>E = Phase
>D = ( A * E )
>D = Amplitude
FAQ: Question about Inverse SQRT of Amplitude
What is the inverse square root of amplitude?
The inverse square root of amplitude is a mathematical calculation used to determine the inverse of the square root of a given value. It is commonly represented as 1/√x, where x is the amplitude.
How is the inverse square root of amplitude used in science?
The inverse square root of amplitude is used in various fields of science, such as physics, engineering, and statistics. It is commonly used in calculations involving wave properties, such as sound and light waves, as well as in determining the intensity of radiation and gravity.
What is the relationship between amplitude and the inverse square root of amplitude?
The inverse square root of amplitude is directly proportional to the amplitude. This means that as the amplitude increases, the inverse square root of amplitude also increases, and vice versa.
Can the inverse square root of amplitude be negative?
No, the inverse square root of amplitude cannot be negative. Since the square root of a negative number is undefined, the inverse of the square root of a negative number is also undefined.
How can the inverse square root of amplitude be calculated?
The inverse square root of amplitude can be calculated using a calculator or by hand using the formula 1/√x. It is also possible to use a table of values or a graph to estimate the inverse square root of amplitude for a given value.
