Question about the Archimedes principle and gravity.
In summary, the conversation discusses the impact of buoyancy on weight and how it differs on Earth compared to a similar planet without an atmosphere. It is mentioned that mass is measured differently and the effect of buoyancy is not usually taken into account when building structures, unless it is being intentionally exploited.
DrSmersh
Hello, I was taking a shower and started to think about balloons and helium and this question came to me:
Wouldn't the things on Earth be lighter than say, a similar planet (same gravity) but with no atmosphere? (because of the push from air)
I googled it but I am not sure of using the correct keywords.
PS: I am starting engineering and my physics knowledge is not very superior to an AP level (I don't really know how to compare our educational systems sorry :P)
That depends on exactly what you mean by weight. They will have the same mass, and experience the exact same amount of force downward, but without a fluid surrounding them the effect of buoyancy will not exist.
Consider this. If I put a scale at the bottom of a pool, you will weigh less inside the pool than outside according to the scale. However if I put both you and the pool onto a scale, your full weight will show.
Thanks for the reply
Considering that air pushes a baloon I assume that it is a fluid, I mean it has the bouyancy effect on everything in the atmosphere. We might not float but we weight less (like a rock under water) if we compare us standing on a scale in a similar planet (equal gravity), is that correct?
So in all the exercises that i did when practicing Newton's laws the result in real life should be different partialy because of this airpush? I suppose the difference would be very small then, but does a civil engineer have to take that in account when building a bridge or any structure for example? Or a phyisist when trying to measure the as close to real as possible mass of a particle or element (I don't know how they measure this things but suposing that in some part of the process they have to weight something and decompose the forces that are presented)?
Mass is measured differently, so we don't really have to worry about that. Plus, if you REALLY want to measure the weight of an object, just take it into a vacuum chamber. In any case, the real world differences are so tiny that in practically all cases you don't need to take them into account in order to build anything. (Unless you are trying to exploit the effect of course)
Awesome thanks, that answers my question.
Related to Question about the Archimedes principle and gravity.
1. What is the Archimedes principle?
The Archimedes principle states that when an object is placed in a fluid, it experiences an upward buoyant force equal to the weight of the fluid it displaces.
2. How does the Archimedes principle relate to gravity?
The Archimedes principle is based on the force of gravity, as the buoyant force is a result of the gravitational pull on the fluid.
3. What is the significance of the Archimedes principle?
The Archimedes principle is important in understanding the behavior of objects in fluids, particularly in predicting whether an object will sink or float.
4. How does the density of an object affect its buoyancy?
The density of an object directly affects its buoyancy according to the Archimedes principle. An object with a higher density than the fluid it is placed in will sink, while an object with a lower density will float.
5. Can the Archimedes principle be applied to gases?
Yes, the Archimedes principle can be applied to gases, as it is based on the concept of buoyancy and displacement. However, the principle may need to be modified to account for differences in the behavior of gases compared to fluids.
17K
