Question with Archimedes' principles
  • Thread starter john8765
  • Tags
    Archimedes
In summary, the cylindrical fishing float, made of polystyrene and negligible mass, has a length of 15cm and an average cross section of 3cm^2. A lead weight of 30g is attached to the bottom using a thin nylon monofilament line. To calculate how far the float will sink into the water, we can use the fact that the upthrust acting on a body is equal to the weight of the fluid displaced. To find the volume of the water displaced, we can use the shape of the float and the density of water. Based on these calculations, the float will sink 0.1m into the water.
john8765
A cylindrical fishing float is 15cm long, with an average cross section of 3cm^2. It is made of polystyrene and has negligible mass. A lead weight of 30g is attached to the bottom of the float using a thin nylon monofilament line.
Question: Calculate how far the float will sink into the water.
Treat g as equal to 10N kg-1
I know Archimedes said upthrust acting on a body is equal to weight of fluid displaced but can't see how to apply that in this case. Thanks for any help.
Can you find an expression for the volume of the water displaced based on the shape of the float? In this case the density of water can be used to find the mass of the water displaced.
Thanks for your help. I've come up with an answer of 0.1m?
You're welcome, I get the same answer.
Based on Archimedes' principle, the buoyant force acting on an object is equal to the weight of the fluid it displaces. In this case, the cylindrical fishing float will displace a volume of water that is equal to its own volume. Since the float is made of polystyrene, which has a density of approximately 1 kg/m^3, its volume can be calculated by multiplying its length (15cm) by its average cross section (3cm^2) which is 0.03m^3.
Therefore, the buoyant force acting on the float is equal to 0.03m^3 x 10N/kg = 0.3N.
Now, taking into account the weight of the lead weight, which is 30g or 0.03kg, the total weight of the float and weight combined is 0.03kg + 0.03kg = 0.06kg.
Using the formula F = ma, where F is the force, m is the mass, and a is the acceleration, we can calculate the acceleration of the float as it sinks into the water.
Since the only force acting on the float is the buoyant force (0.3N) and the weight of the float and weight combined is 0.06kg, we can set up the following equation:
0.3N = 0.06kg x a
Solving for a, we get a = 5m/s^2.
Now, using the equation d = 1/2at^2, where d is the distance, a is the acceleration, and t is the time, we can calculate the distance the float will sink into the water in a given amount of time.
Assuming the float starts from rest, we can set t = 1 second.
Therefore, d = 1/2 x 5m/s^2 x (1s)^2 = 2.5m
This means that in 1 second, the float will sink 2.5m into the water.
In conclusion, the float will sink 2.5m into the water when the lead weight is attached to the bottom using a thin nylon monofilament line. It is important to note that this calculation is based on ideal conditions and may vary in real-life situations due to factors such as water currents and the angle at which the weight is attached
Related to Question with Archimedes' principles
What is Archimedes' principle and how does it work?
Archimedes' principle is a physical law that states that the buoyant force on an object submerged in a fluid is equal to the weight of the fluid displaced by the object. This means that the upward force on an object in a fluid is equal to the weight of the fluid that is pushed out of the way by the object.
What is an example of Archimedes' principle in action?
An example of Archimedes' principle is a ship floating in water. The weight of the water displaced by the ship is equal to the weight of the ship, allowing it to float.
How does the density of an object affect its buoyancy according to Archimedes' principle?
The density of an object affects its buoyancy by determining how much of the object's volume is submerged in the fluid. If the density of the object is greater than the density of the fluid, it will sink because it will displace less fluid than its own weight. If the density of the object is less than the density of the fluid, it will float because it will displace more fluid than its own weight.
What other factors can affect the buoyancy of an object according to Archimedes' principle?
In addition to density, the size and shape of an object can also affect its buoyancy. Objects with larger surface areas will experience greater buoyant forces and will therefore float more easily. Objects with irregular shapes may displace different amounts of fluid depending on their orientation, which can affect their buoyancy.
What is the difference between buoyancy and weight according to Archimedes' principle?
Buoyancy is the upward force exerted on an object by a fluid, while weight is the downward force exerted on an object by gravity. According to Archimedes' principle, buoyancy is equal to the weight of the fluid displaced by an object, whereas weight is determined by the mass of the object and the strength of the gravitational field it is in.
10K
