Quick Question (Epsilon/Delta Limit Proofs)
In summary, "Quick Question (Epsilon/Delta Limit Proofs)" is a concept used in mathematics to prove the limit of a function by using the epsilon-delta definition. It is typically used when the limit of a function at a specific point is not obvious. The epsilon-delta definition of a limit states that the limit is equal to a given value if there exists a corresponding value of delta that ensures the output is within a certain range of the given value. The steps for solving "Quick Question (Epsilon/Delta Limit Proofs)" involve setting up the definition, manipulating the expression, and using algebraic techniques to prove the limit. Some helpful tips for solving these types of proofs include starting with a small value of epsilon and carefully
amd123
110
[PLAIN]http://img641.imageshack.us/img641/2494/mathg.png
I've worked through it and at the 1st step I get:
(1/-e+1)<x<(1/e+1)
How do they have
(1/e+1)<x<(1/-e+1)?
Do you switch the signs of an inequality when you take the inverse of both sides?
1<2. 1/1>1/2. Yes, you do reverse the inequalities when you invert.
FAQ: Quick Question (Epsilon/Delta Limit Proofs)
What are "Quick Question (Epsilon/Delta Limit Proofs)"?
"Quick Question (Epsilon/Delta Limit Proofs)" is a mathematical concept used to rigorously prove the limit of a function using the epsilon-delta definition of a limit.
How do I know when to use an epsilon-delta proof?
Epsilon-delta proofs are typically used when proving the limit of a function at a specific point, where the limit may not be obvious or intuitive.
Can you explain the epsilon-delta definition of a limit?
The epsilon-delta definition of a limit states that the limit of a function at a point is equal to a given value L if for any positive value of epsilon, there exists a corresponding positive value of delta, such that when the input is within delta units of the given point, the output is within epsilon units of the given value L.
What are the steps for a "Quick Question (Epsilon/Delta Limit Proofs)"?
The steps for a "Quick Question (Epsilon/Delta Limit Proofs)" typically involve setting up the epsilon-delta definition, manipulating the expression to find a suitable value for delta, and using algebraic techniques to prove that the output is within epsilon units of the given value L.
Are there any tips for solving "Quick Question (Epsilon/Delta Limit Proofs)"?
One helpful tip is to start with a small value of epsilon and work your way up, as it may be easier to find a corresponding value of delta for a smaller epsilon. It's also important to carefully manipulate the expression and use algebraic techniques to simplify and prove the limit.
