Radiation emitted by wired keyboard
In summary, a keyboard emits radiation when a key is clicked. It is unclear if it is possible to determine which key was pressed, but all keyboards would emit a similar radio 'click'. This is done all the time by spies and hackers.
YanivW
Hi,
I heard before that wired keyboards emits radiation when a key is clicked. My goal is to build a keylogger based on this phenomenon (for fun, of course). I've already seen some variations of this idea, but they were all using wireless keyboard, where it is much more simple to detect and process the RF radiation.
I want to learn more about this, but can't find anything on the internet (the spectrum of the emitted radiation for example). I'll be glad if someone could help me find more information that can be relevant, or share from his own knowledge.
Thanks!
You'll need to give a link to this supposed phenomenum.
However any electrical switch will emit a tiny amount of EM radiation when the contact is closed.
Mainly 'white noise' at the very low end of the spectrum (aka radio).
In the case of a keyboard I doubt there is a way to determine which particular key was pressed,
All of them would emit a similar radio 'click'
:wink:Too bad you can't send your question to the NSA. If it can be done, they probably did it.
Likes YanivW and davenn
Well, do you have any idea of what frequencies it probably emitting? I guess the phenomenon is basically what you mentioned, but I still want to get an antenna and figure out if there's any way to determine the differences between the keys. What type of antenna should I buy? Will regular RF antenna be good, in your opinion?
Not surprised it's been done. Way back in the 1980s there was concern that it was possible to read a CRT display by decoding it's electromagnetic emissions at a distance. If I remember correctly it was even demonstrated on a UK TV program. Obviously it was much easier back then when monitors were similar to TV's.
The keyboard is scanned row by row. Those scan pulses generate electromagnetic waves. If a key is pressed, it changes the corresponding scan pulse slightly - and that can be picked up remotely by a sensitive receiver. Knowing the row scan sequence allows you to guess what key is pressed.
This is very general, but it is what I was told when the military wanted a keyboard that could not be tapped remotely. My solution was to introduce a short pseudo-random generator in front of the row scanner, so the row sequence was undecipherable. In any case, they were satisfied and ordered a bunch of those keyboards.
Likes Jeff Rosenbury
This sort of thing is done all the time by spies and hackers. I'm sure there's equipment on the darknet.
I could give advice, but first I would need some assurances you were using it for legal purposes. Personally I can't think of any legal purposes, but perhaps you can.
Imagine reading someone's bank password... Lucrative, but not really legal.
Nidum said:
Thanks a lot! This is really helpful.
Well I'm just a 2nd year EE student seeking for some cool challenging project to start with (-:
Related to Radiation emitted by wired keyboard
What is "radiation" emitted by wired keyboard?
"Radiation" emitted by wired keyboard refers to the electromagnetic radiation that is emitted from the keyboard while it is in use. This radiation is in the form of low frequency electromagnetic fields (EMF) which are produced by the flow of electricity through the keyboard's wires and circuits.
Is the radiation emitted by wired keyboards harmful?
The radiation emitted by wired keyboards is considered to be non-ionizing radiation, meaning it does not have enough energy to damage cells and cause harm. However, prolonged exposure to high levels of EMF radiation can potentially have negative effects on human health, such as fatigue, headaches, and sleep disturbances.
How can I reduce my exposure to radiation from a wired keyboard?
To reduce your exposure to radiation from a wired keyboard, you can try using a keyboard with a shorter cord or a wireless keyboard. Additionally, you can also keep a distance between yourself and the keyboard while using it, and take breaks from using the keyboard to allow your body to rest and recover.
Are there any regulations for the amount of radiation emitted by wired keyboards?
There are currently no specific regulations for the amount of radiation emitted by wired keyboards. However, most countries have set limits for occupational exposure to electromagnetic radiation, and keyboard manufacturers are required to comply with these limits.
Are there any alternative keyboard options that emit less radiation?
Yes, there are alternative keyboard options that emit less radiation, such as keyboards with shorter cords or wireless keyboards. Additionally, some keyboards are designed with shielding materials to reduce the amount of EMF radiation emitted. It is also important to regularly check for electromagnetic radiation levels when purchasing a new keyboard.
