Radius and interval of convergence for
In summary, The conversation discusses finding the radius and interval of convergence for a given series. The ratio test is applied and the denominator is determined to be represented by 1*3*5...(2n-1). The ratio test is then used to determine that the series converges for all x^n, with an infinite radius of convergence. A technical aspect of the ratio test is also mentioned.
philnow
83
Hey all. I'm being asked to find the radius and interval of convergence for the series from 1 to infinity:
x^n/(1*3*5...(2n-1))
I have a feeling this is pretty straight forward (just apply the ratio test etc...), but my trouble lies in defining the denominator. Something to do with factorials? How do I get something to represent 1*3*5 all the way to *(2n-1)?
Ok, so a_n=1/(1*3*5...(2n-1)). I think that represents it pretty well. What's a_(n+1)/a_n?
a_(n+1)/a_n would be =
1*3*5...(2n-1) / 1*3*5...(2n-1)(2n+1)
correct? In this case it simplifies to 1/(2n+1)?
Absolutely correct. So what does the ratio test tell you?
Convergent for all x^n I believe, so radius of convergence = inf?
Sure. lim a_(n+1)/a_n=0. So infinite radius of convergence. Converges for all x.
Thanks very much!
Just to nitpick on the absolutely perfect argument above --- it's technically an implication of the ratio test and not because of the ratio test. If the power series is of the form [tex]\sum a_n x^n[/tex], then we define [tex]\beta = \limsup |a_n|^{1/n}[/tex] and the radius of convergence as [tex]R = 1 / \beta[/tex].
So, technically, one is supposed to compute [tex]\beta[/tex], but often it is hard to compute the n-th root of things. But the trick is that we see this inequality relationship
[tex]\liminf |a_{n+1} / a_n| \leq \liminf |a_n|^{1/n} \leq \limsup |a_n|^{1/n} \leq \limsup|a_{n+1} / a_n|[/tex]. And since if [tex]\lim |a_{n+1} / a_n|[/tex] exists, then [tex]\lim |a_{n+1} / a_n| = \liminf |a_{n+1} / a_n| = \limsup|a_{n+1} / a_n|[/tex], implying immediately that [tex]\limsup |a_n|^{1/n} = \lim |a_{n+1} / a_n| [/tex].
I'm just nitpicking :P
FAQ: Radius and interval of convergence for
What is the definition of radius of convergence for a power series?
The radius of convergence for a power series is the distance from the center of the series to the nearest point at which the series converges. It is denoted by the variable 'R' and can be calculated using the ratio test or the root test.
How do you determine the interval of convergence for a power series?
The interval of convergence for a power series is determined by finding the values of x for which the series converges. This can be done by using the ratio test or the root test, and then checking the endpoints of the interval separately for convergence.
Can a power series have an infinite radius of convergence?
No, a power series must have a finite radius of convergence. This is because the series must converge for at least one value of x, and if the radius of convergence were infinite, the series would converge for all values of x, which is not always the case.
How does the behavior of the series change at the endpoints of the interval of convergence?
The behavior of the series at the endpoints of the interval of convergence can vary. In some cases, the series may converge at one or both endpoints, while in other cases, the series may diverge at one or both endpoints. It is important to check the endpoints separately when determining the interval of convergence.
Can you use the ratio test to determine the interval of convergence for all power series?
No, the ratio test can only be used to determine the interval of convergence for power series with positive coefficients. For power series with alternating coefficients, the alternating series test must be used to determine convergence. Additionally, the ratio test may not always give a conclusive result, in which case other methods must be used to determine the interval of convergence.
