Ratings of Fuses for household applications?
In summary, the rating of conventional rewirable fuse and MCB (miniature circuit breaker) is related to the amount of current they can handle. Polyfuses, also known as resettable or PPTC fuses, are commonly used in electronic circuits but cannot be used to replace conventional household power supply main fuses due to safety regulations. They have limitations and may not disconnect the equipment from the electricity supply in the event of overcurrent, making them unsuitable for household circuits.
jobinhere
What is the rating of conventional rewirable fuse, MCB etc.
What is the rating of polyfuse(resettable fuse or PPTC fuse). Polyfuse are normally used in electronic circuits.
Can we replace conventional household power supply main rewirable fuse with these polyfuse. Is it available in such high power requirement?
Pls help.
Pls help.
Welcome to the PF.
What's an MCB?
In general, I don't think you can replace a real fuse with a polyfuse. What is your application?
MCB = miniature circuit breaker.
Then, In which all places, we can use a polyfuse.
What are its limitations?
Why can't we replace a conventional rewirable fuse/MCB in electric circuits in our home by a Polyfuse?
Hello jobinhere what is your normal working discipline?
Is English your first language?
Any competent electrical engineer or electrician would tell you that the correct term for what is popularly called a household fuse is actually a 'disconnection device'.
The important part here is the word disconnection.
The regulations in most countries require a device which actually disconnects the attached equipment from the electricity supply in the event of overcurrent.
Polyfuses (again a popular misnomer) may not be used because they do not disconnect the apparatus.
This is an extremely important safety matter which should not be taken lightly.
The polyfuse only increases in resistance when it is overloaded. When it cools down, the resistance returns to its regular low value.
So it is useful for protecting some electronic circuits from overcurrent conditions, but only if the short-circuit condition that caused the overcurrent is of short duration. If the short circuit fault condition is permanent, the polyfuse will eventually fail...
http://en.wikipedia.org/wiki/Resettable_fuse
A fuse or breaker is there to protect the user and the building (wiring), not the connected electronic circuit.
FAQ: Ratings of Fuses for household applications?
What are fuses used for in household applications?
Fuses are used to protect electrical circuits from overloading and short circuits. They act as a safety mechanism by breaking the circuit if too much current flows through it, preventing damage to appliances or potential fire hazards.
How do I know what rating of fuse to use for my household appliances?
The rating of a fuse is determined by the amount of current it can safely handle. To select the appropriate fuse for your appliance, you need to know the appliance's voltage and wattage. You can then use a fuse chart or consult an electrician to determine the correct rating.
Can I use a higher rated fuse for my household appliances?
No, it is not recommended to use a higher rated fuse for your household appliances. Fuses are designed to protect the circuit and using a higher rated fuse can result in damage to your appliances or potential fire hazards.
Can I replace a fuse with a circuit breaker?
Yes, a circuit breaker can be used in place of a fuse for household applications. However, it is important to ensure that the circuit breaker has the same rating as the fuse it is replacing.
How often should I check and replace fuses in my household?
It is recommended to check your fuses at least once a year to ensure they are in good working condition. If you notice any signs of damage or if a fuse has blown, it should be replaced immediately. It is also a good idea to replace all fuses in your household every 5-10 years to ensure they are functioning properly.
