Raychaudhuri Shear Equation in Different Sign Conventions
In summary, the conversation discussed the derivation of Raychaudhuri Equations in different sign conventions and the impact of the sign change in the Projection Tensor on the Shear equation. It was also mentioned that the Weyl tensor has different signs under different conventions and that spatial tensors are defined with respect to a specific spatial coordinate system in general relativity.
sharmax
Hi, I derived Raychaudhuri Equations in both (- + + +) and (+ - - -) sign conventions from metric. In Robert Wald and Sean Carroll books, (- + + +) sign convention and I derived correctly in that Sign Convention as given in the books. In the other convention, I am having one sign difference in Shear equation, because I changed the Sign in Projection Tensor (Pμν) to save some properties on the whole derivation is based. These are: -
BμνUμ = 0 = BμνUν
where Uμ is tangent vector field
Similar properties exist for shear (σμν) and rotation (ωμν)
To prove them, in (- + + +) convention
Pμν = gμν + UμUν
But in (+ - - -) convention
Pμν = gμν - UμUν
Because of this, the Riemann part of Shear equation in (- + + +) convention is
CταβμUμUν + ½Rαβ
while in (+ - - -) comes up as
CταβμUμUν - ½Rαβ
where Rαβ is spatially projected trace-less part of Ricci. I am pretty sure about the reason why the sign change is occurring (that is the change of sign in Projection Tensor in which makes it look correct thing to happen) but another possibility is that maybe Weyl tensor (Cταβμ) has different signs under different conventions and I don't know about that. Please Help!
Also what are "spatial" tensors?
Hi there,
Thank you for sharing your findings on the Raychaudhuri Equations in different sign conventions. It is interesting to see that the change in sign of the Projection Tensor can have an impact on the Shear equation.
To address your question about the Weyl tensor, it does in fact have different signs under different conventions. In the (- + + +) convention, the Weyl tensor has the form Cταβμ = Rταβμ - ½(Rαβgμτ - Rαμgβτ + Rβμgατ), while in the (+ - - -) convention, it has the form Cταβμ = Rταβμ + ½(Rαβgμτ - Rαμgβτ + Rβμgατ). This difference in sign is due to the different sign conventions used for the Riemann tensor.
As for "spatial" tensors, these are tensors that are defined with respect to a specific spatial coordinate system. In general relativity, the spacetime is described by a 4-dimensional manifold, with 3 dimensions representing space and 1 dimension representing time. A spatial tensor is one that is defined only in the 3 spatial dimensions, and does not involve the time dimension. This is in contrast to a spacetime tensor, which is defined in all 4 dimensions.
I hope this helps to clarify your questions. Keep up the good work in your research!
Related to Raychaudhuri Shear Equation in Different Sign Conventions
1. What is the Raychaudhuri Shear Equation and how is it used in different sign conventions?
The Raychaudhuri Shear Equation is a mathematical equation used in the study of general relativity. It describes the evolution of a congruence of timelike or null geodesics (the paths of particles or light) in a curved spacetime. The equation also takes into account the effect of shear, which is a measure of the distortion or stretching of the geodesics. Different sign conventions refer to the use of positive or negative signs in the equation, which can change the interpretation of the results.
2. How does the Raychaudhuri Shear Equation differ in different sign conventions?
In the standard sign convention, the Raychaudhuri Shear Equation has a negative sign in front of the shear term, indicating that shear has a focusing effect on the geodesics. However, in some alternative sign conventions, the sign in front of the shear term may be positive, resulting in a repulsive effect on the geodesics. This can lead to different predictions about the behavior of particles or light in a curved spacetime.
3. What are the implications of different sign conventions in the Raychaudhuri Shear Equation?
The choice of sign convention in the Raychaudhuri Shear Equation can affect the interpretation of the results in terms of the dynamics and geometry of the spacetime. It can also have consequences for the predictions of physical phenomena, such as the formation of black holes or the expansion of the universe. Therefore, it is important to carefully consider the sign convention used in any application of the equation.
4. How is the Raychaudhuri Shear Equation used in cosmology?
The Raychaudhuri Shear Equation is a fundamental tool in the study of cosmology, particularly in the study of the large-scale structure of the universe and the evolution of cosmic structures such as galaxies and galaxy clusters. It can be used to predict the behavior of matter and energy in the expanding universe, and to understand the effects of gravity on the formation and evolution of cosmic structures.
5. Are there any experimental tests of the Raychaudhuri Shear Equation in different sign conventions?
While there have been theoretical studies and numerical simulations examining the consequences of different sign conventions in the Raychaudhuri Shear Equation, there have not been any direct experimental tests. However, the predictions made by the equation have been confirmed by various observations in cosmology, providing indirect evidence for the validity of the equation regardless of the sign convention used.
