- 23,093
- 7,501
Is the width of spectral emission/absorption lines stretched in either cosmological or doppler redshift?
Well, if you think about it, the lines have to be broadened by the exact same amount as the wavelength is lengthened.Drakkith said:Is the width of spectral emission/absorption lines stretched in either cosmological or doppler redshift?
Chalnoth said:Well, if you think about it, the lines have to be broadened by the exact same amount as the wavelength is lengthened.
Imagine, for a moment, that some source emits light between 100nm and 101nm. If that source is at a redshift of 1, then the 100nm lower part will be redshifted to 200nm, while the upper wavelength of 101nm will be redshifted to 202nm, changing a 1nm width line to 2nm width.
I don't think that there are any additional effects on top of this that would broaden the lines further (though interaction with matter can do that).
That's positively ridiculous.Gabrell said:According to variable mass theory, we see redshifts because we see objects as they were when the light left them.
The Redshift Effect is a phenomenon in which the wavelengths of electromagnetic radiation from distant objects appear longer (shifted towards the red end of the spectrum) due to the expansion of the universe. This is a consequence of the Doppler effect, which causes the wavelength of light to change when the source and observer are moving relative to each other.
When light from a distant object is redshifted, the absorption and emission lines in its spectrum are also shifted towards longer wavelengths. This is because the absorption and emission processes that produce these lines are dependent on the energy levels of the atoms or molecules, which are also affected by the redshift. Therefore, the redshift can provide important information about the composition and physical conditions of the object.
Absorption lines occur when atoms or molecules in a cooler gas absorb specific wavelengths of light, leaving gaps or dark lines in the spectrum. Emission lines, on the other hand, are produced when atoms or molecules in a hotter gas emit light at specific wavelengths as they transition between energy levels. The presence and characteristics of these lines can reveal important information about the composition and temperature of the gas.
The Redshift Effect is a key tool for astronomers to measure the distance and velocity of objects in the universe. By measuring the redshift of absorption and emission lines in the spectra of distant objects, scientists can determine how fast these objects are moving away from us and how far away they are. This information has been crucial in developing our current understanding of the expansion of the universe and the structure and evolution of galaxies.
Yes, the Redshift Effect can also be applied to objects within our own galaxy. By measuring the redshift of absorption and emission lines in the spectra of stars and gas clouds within the Milky Way, scientists can gather information about their motion and distance. This has been particularly useful in studying the rotation and structure of our galaxy.
