Regarding Riemann integration defination
In summary, the Riemann integration definition states that a function is Riemann integrable if it is bounded and the limit of the norm of the partition tends to zero as the lower and upper Darboux sums also tend to zero. This means that the number of points in the partition increases without bound, but is never infinite. Additionally, it is not necessary for the function to be continuous, as long as the set of discontinuities has a measure of zero.
seshikanth
Regarding "Riemann integration defination"
Hi,
I did not understand the following:
We have : Partition is always a "finite set".
A function f is said to Riemann integrable if f is bounded and
Limit ||P|| -> 0 L(f,P) = Limit||P|| -> 0 U(f,P)
where L(f,P) and U(f,P) are lower and upper Darbaux Sums, ||P|| is the norm of Partition.
If ||P|| -> 0 then we have max sub-interval length = 0 => we have infinite points in Partition which leads to contradiction of definition of Partition being "FINITE SET".
I think i am missing something here!
Thanks,
seshikanth said:
Hi,
Thanks,
the number of points in the partition increases without bound but is never infinite.
There is no limiting partition, only a limiting value for the Riemann sums.
Can you please elaborate? The norm of partition tending to zero implies that the number of points in the partition also tends to infinite.
Thanks,
Thanks,
yes but each partition is finite. As the norm of the partition shrinks the number of finite points in it increases without bound - but it is never infinite. In the limit there is no partition.
Example: integrate the function f(x) = x over the unit interval. A typical Riemann sum with n partition points looks like
(1 + ... + n-1)/n^2 = 1/2(n-1)n/n^2 = 1/2(n-1)/n = 1/2( 1-1/n). As n goes to infinity this goes to 1/2.
If the norm shrinks and shrinks tending towards zero, How can the number of points in the partition be finite? This is where i am thinking! (Lower Darbaux sum will be equal to Upper Darbaux sum only when the number of intervals tends to infinite)
I just added an example.
The numbers 1,2 ...n, n+1, ... tend to infinity but never get there. That is the same for the number of partition points
Got it!
One more question: Please correct me if i am wrong here-
"If a function f is Riemann integrable on closed and bounded interval [a,b] then f is continuous on [a,b] and also the converse is also true"
i.e., Riemann integrable <=> f being continuous
no. It does not have to be continuous. But the set of discontinuities must have measure zero.
Try calculating the Riemann sums for the function that is 1 from 0 to 1/2 and 2 from 1/2 to 1.
Intuitively you can see that the area under this discontinuous function is the area under two rectangles.
FAQ: Regarding Riemann integration defination
What is the definition of Riemann integration?
The Riemann integration is a method of calculating the area under a curve using rectangles. It is based on the concept of dividing the area under the curve into smaller and smaller rectangles, and then summing up the areas of these rectangles to get an approximation of the total area.
How is Riemann integration different from other methods of integration?
Riemann integration is a specific type of integration that uses rectangular approximations, while other methods such as the Trapezoidal rule and Simpson's rule use trapezoids and parabolas, respectively. Riemann integration is also considered to be a simpler and more intuitive approach to integration.
What are the key components of the Riemann integration definition?
The key components of the Riemann integration definition are the partition of the interval, the choice of sample points, and the limit of the sum as the width of the rectangles approaches zero. These components determine the accuracy of the approximation of the area under the curve.
What are the applications of Riemann integration in real life?
Riemann integration has many applications in physics, engineering, and economics. It is used to calculate the work done by a variable force, the center of mass of an object, and the cost of production in economics, among others.
What are the limitations of Riemann integration?
Riemann integration can only be used to integrate continuous functions and may not provide an accurate result for functions with sharp corners or discontinuities. It also requires a large number of rectangles to achieve a more accurate approximation, which can be computationally expensive.
