Regarding the finding of domains of functions
In summary: The approach of defining the function for all possible objects can be unhelpful because it may include objects for which the function does not make sense. It is important to specify a domain for the function, and often we want to define the function on a subset of the reals. In this case, we can find the domain of the function by removing any elements for which the function is undefined.
d1ngell
First of all, I would like to appologize if I'm posting this in the wrong section, although I believe it to fit this area.
I'm usually not convinced when books claim to have found the natural domain of certain functions. For instance, this book I've been reading has defined the natural domain of a function as the largest set of elements whose range is in the real numbers set.
Ever since I've been having trouble accepting that the domain of functions such as f(x) = x² is ℝ.
Should I give [itex]\sqrt{-1}[/itex] as input value, the function would return -1, which is a real number. Therefore, I would be taken into accepting that the domain would be at least ℝ[itex]\cup[/itex]{[itex]\sqrt{-1}[/itex]}, for its range is still ℝ. What should be the bound when looking for a function's domain?
Thanks in advance,
d1ngell
Mathematics news on Phys.org
It is silly that books say "Find the domain of this function." The definition of a function includes the domain. Your approach is not much better. By defining the function for all objects for which it makes sense we expand the function in a way that is not necessarily helpful. For example if we know x is real it is not helpful to define x^2 for non-real x. We might go further and define x^2 for matrices and all sorts of other object which is still not helpful. The point your book is making (poorly) is that given a set that contains the domain we can find the domain by throwing out the elements for which the function is undefined. Often we want to define functions on subsets of the reals, so we define it for all reals that are reasonable.
What you're saying is that the domain of a function may vary depending upon application? I can see that, for example, when calculating the area of a circle given a radius. A(r) = πr², and the domain would be [itex]\Re[/itex][itex]^{+}_{*}[/itex]
I'm sorry if I'm bothering by asking, but I have had trouble understanding the following: "The point your book is making (poorly) is that given a set that contains the domain we can find the domain by throwing out the elements for which the function is undefined."
What I understand from that is that, disconsidering the unhelpfulness of the expansions of the functions, the [itex]\Re[/itex], commonly called domain of functions such as f(x) = x², would not be in fact the largest set of numbers to whom the function returns real values, hence not being the natural domain of the function.
(I would like to apologize once again if I'm sounding stupid. I'm brazilian so I eventually have a little bit of difficulty understanding some things. Rephrasing usually solves it.)
The domain refers to inputs and the range/co-domain refers to outputs.
That's pretty much all there is to worry about.
Do you know Portuguese? Do you live near a beach? To define the natural domain we need to start with a set of possible numbers for the domain and range. I take it you book is using the real numbers for the domain and range. The complex numbers and integers are other possible choices. In the real case the natural domain is the set of all real numbers x for which f(x) is real.
for x2
If the starting set is real numbers the natural domain is all real numbers
If the starting set is complex numbers the natural domain is all complex numbers
If the starting set is complex numbers, but we require the function to be real the natural domain is a all real and pure imaginary numbers.
The trouble when we ask about all elements such that x2 is real is where do you stop? Besides real and imaginary numbers we could have dual numbers, split complex numbers, quaternions, and any number of other types of numbers. Usually we have some number system in mind like real or complex numbers and we do not care about the values of the function for other types of numbers. So to answer your original question is that $$\sqrt{-1}$$ should be in the domain if you are working with complex numbers.
I strongly suspect that your textbook had already, implictely or explicitely, said that it was talking about real valued functions defined on the real numbers.
I think chiro didn't really understand my question, which has been properly solved by lurflurf with HallsofIvy's contribution. Now I understand what you're saying. As HallsofIvy mentioned, my book does indeed talk about real valued functions, although I never really thought about that as being an inferrence that I should always consider the real numbers as the largest set when inspecting all the possible input values for the functions. Thank you for your answers.
@lurflurf
Yes, Portuguese is my main language. I currently live in the brazilian capital, Brasília, which isn't a costal city. I have lived for about 8 months in front of the beach, though.
But the domain might not be given explicitly. At the precalculus level it's reasonable to ask for the domain of the function f(x) = √(3 - x2).
Related to Regarding the finding of domains of functions
What are domains of functions?
Domains of functions refer to the set of all input values for which a function is defined and can produce a valid output.
Why is it important to identify the domain of a function?
Identifying the domain of a function is important because it helps determine the set of values for which the function is valid and provides meaningful results. It also helps in understanding the behavior of the function and its limitations.
How do you find the domain of a function?
The domain of a function can be found by looking at the given equation and identifying any restrictions or limitations on the input values. For example, in a rational function, the denominator cannot be equal to zero, so the domain would exclude any values that make the denominator equal to zero.
Can the domain of a function change?
Yes, the domain of a function can change if there are any changes made to the function itself. For example, if a function is modified by adding or subtracting a constant value, the domain may change accordingly.
What happens if the domain of a function is not specified?
If the domain of a function is not specified, it is assumed to be all real numbers. However, it is important to note that there may be certain restrictions or limitations on the domain that need to be taken into consideration for the function to produce valid and meaningful results.
