Relativistic Momentum and energy conservation
In summary, the conversation is about two observers studying special relativity and discussing the velocities and energy conservation of two colliding bodies. The relative velocity between the two bodies is found to be approximately 0.97c, and the energy in the two frames of reference is significantly different. The conversation ends with one observer questioning the reason for this difference.
nard
Hello everyonea. I was studying special relativity and i got stuck on an example. Here it is:'to an observer,two bodies of equal rest mass collide head on with equal but opposite velocities 0.8c and cohere. To a second observer,one body is initially at rest. Find the apparent velocity of the other moving mass before the collision and compare its initial energy in the 2 frames of reference.'
i am trying to find their relative velocity but am finding a value greater than c. Can somebody help me on this or give some tips on how i should start. Thanks for understanding.
Hello nard! :smile:
That shouldn't be possible. :confused:
What formula are you using (from memory, I think it should be (u+v)/(1+uv))?
This is the derivationhttp://en.wikipedia.org/wiki/Velocity-addition_formula"
Another mistake is that you didn't name yourself properly:smile:
I used lorentz transformations, i found a velocity which is less than c,however i stil don't know how to procede
Show us what you did. :smile:
u'=(u-v)/(1-uv/c^2), where u' and u are speeds of the body in different frames and v their relative velocity.
for viewer 1.
P1+P2=P3 from momentum conservation but P1=-P2, then
P3=0
E1+E2=E3 from energy conservation but E1=E2;
2E1=E3;
for viewer 2.
P1'=P3' since P2' is zero;
E1'+moc^2=E3';
whats next i don't know
for viewer 1.
P3=0
2E1=E3;
for viewer 2.
E1'+moc2=E3';
Hello nard! :smile:
erm :redface: … you're not actually answering any of the question …
To rewrite it, the question is, if the velocities in one frame are ±0.8c, what is one velocity in the frame in which the other velocity is 0? In other words (as you say), what is the relative velocity?
And what is the energy in the two frames?
(you're not asked to solve any collision problem)
So what figures did you get? :smile:
hello! the relative velocity in the frame where the two masses have equal velocities(.8c) and different directions is aproximatly(.97c).
in the frame where one mass is at rest the velocity of the moving one is equal to the relative velocity(.97c).
now if we compare the two energies in frame 1 E1=1.66moc^2
and E1'=4.41moc^2
now the remaining question is why the big difference in energy in the frames.
Hello nard! :smile:
(try using the X2 tag just above the Reply box :wink:)
Yes, that looks right :smile:
(but I'd be inclined to do it a bit more accurately than .97 … it's the difference between that and 1.0 which is important, and you've only got that to one sig fig! :wink:)
and E1'=4.41moc^2
(one reason why exam questions often use 0.8c is that it uses the 3,4,5 Pythagorean triangle, so things tend to turn out as exact fractions … this one does, if you try it :wink:)
"why the big difference?"
'cos that's the way it is!
what's worrying you about that? :smile:
FAQ: Relativistic Momentum and energy conservation
What is relativistic momentum?
Relativistic momentum is a concept in physics that takes into account the effects of special relativity on an object's momentum. It is a measurement of the object's mass and velocity, and is given by the equation p = mv/√(1-v^2/c^2), where m is the object's rest mass, v is its velocity, and c is the speed of light.
How is relativistic momentum different from classical momentum?
Classical momentum is defined as the product of an object's mass and velocity, and is given by the equation p = mv. Relativistic momentum takes into account the effects of special relativity, such as time dilation and length contraction, which become significant at high speeds. This means that as an object's velocity approaches the speed of light, its relativistic momentum will increase while its classical momentum remains constant.
What is energy conservation in relation to relativistic momentum?
Energy conservation is a fundamental principle in physics that states that energy cannot be created or destroyed, only transformed from one form to another. In the context of relativistic momentum, this means that the total energy of a system must remain constant, even as an object's momentum changes due to its relativistic speed.
How does the concept of mass-energy equivalence relate to relativistic momentum?
The concept of mass-energy equivalence, famously expressed by Einstein's equation E = mc^2, states that mass and energy are two forms of the same thing. This means that as an object's velocity increases and its relativistic momentum increases, its energy also increases. This increase in energy is accounted for by the object's increase in mass.
Can relativistic momentum be applied to all objects, or only those moving at high speeds?
Relativistic momentum can be applied to any object, regardless of its speed. However, the effects of special relativity become more significant at high speeds, so the equations for relativistic momentum are typically only used for objects moving at a significant fraction of the speed of light.
