Relativistic Treatment of Core Electrons (DFT)
In summary, the relativistic treatment of core electrons in Density Functional Theory (DFT) considers the effects of special relativity on the electronic structure of atoms and molecules. This approach accounts for the high speeds of electrons and their interactions with the nucleus, leading to more accurate and realistic calculations. By incorporating relativistic effects into DFT, researchers are able to better understand the behavior of core electrons and their role in chemical bonding and reactivity. This has important implications for various fields, including materials science, drug design, and catalysis.
citw
72
I realize this is something I should probably know intuitively, but why are core states (generally) treated relativistically in density functional calculations? What exactly makes these relativistic bound states rather than non-relativistic? I think this is some basic physics I'm forgetting.
For example, the fact that mercury is liquid unlike most metals and that gold is not silver-colored are results of relativistic effects.
The closer the orbiting electron is to the nucleus, the higher the expectation value of its speed (result of position-momentum uncertainty principle), and relativistic effects are therefore more important in the case of core electrons.
Could you explain this consequence of the uncertainty principle?
When the electron is more localized near the nucleus (like in a core orbital), we know its position more precisely, and therefore its momentum is more uncertain according to the equation [itex]\Delta x \Delta p \geq \frac{\hbar}{2} [/itex] . When the momentum is more uncertain, the expectation value of speed (norm of velocity vector) must be higher. At high speeds, relativistic effects become important.
Sorry, I thinking I'm missing something obvious. If
[tex]\Delta x\Delta p_x\geq \frac{\hbar}{2}[/tex]
and Δx is small near the nucleus, Δp is large, meaning
[tex]\Delta p_x=\sqrt{\big<p^2\big>-\big<p\big>^2}[/tex]
is large... the uncertainty in momentum should be large, but wouldn't this be more suggestive of a smaller momentum expectation value? E.g.,
[tex]\text{if }\sqrt{\big<p^2\big>-\big<p\big>^2}\text{ is large, } \big<p\big>^2\text{ could be small, or }\big<p^2\big>\text{ could be large.}[/tex]
If the electron is in a bound state, [itex]\big<p\big>=0[/itex], because in the center-of-mass frame the electron is not moving to any specific direction on average. A higher uncertainty of momentum implies a higher expectation value for its absolute value.
The higher speed near the core is related to <KE> not dp, and can be understood via the virial theorem (http://en.wikipedia.org/wiki/Virial_theorem), which applies to both QM and CM. Briefly, there is a definite mathematical relationship between <KE> and the mean potential for a Coulombic potential.
Note that in a closed shell atom, the potential at a distance R from the nucleus, V(R), depends mainly on the charge that is located in the region between 0 and R (from Gauss' Law). So, deep core electrons in heavy atoms experience a largely unshielded nuclear potential.
I believe that hilbert2 is essentially answering the question of how core electrons come about, which is more closely related to the uncertainty principle.
Likes 1 person
^ Yes, we don't even need quantum mechanics to see that a particle orbiting in a [itex]1/r[/itex] potential has to have high orbital speed if [itex]r[/itex] is small. The centripetal acceleration of the particle in circular orbit is [itex]a = \frac{v^{2}}{r}[/itex], and as [itex]a\propto \frac{1}{r^{2}}[/itex] we get [itex]v \propto \sqrt{\frac{1}{r}}[/itex] .
In the solar system the planet Mercury, which is closest to the sun, has highest orbital speed and its orbital motion does not agree fully with Newtonian mechanics but can be explained with special relativity.
Likes 1 person
Both their potential and kinetic energy are higher than that of the valence electrons. The high kinetic energy means that they have speeds near the speed of light so that relativistical corrections become important.
What I've been trying to figure out (and what everyone is trying to explain to me) is why this is the case.
Ok, this is what I was thinking (stronger attraction near the nucleus), the the virial theorem is the perfect explanation. This is great, thanks.
FAQ: Relativistic Treatment of Core Electrons (DFT)
What is the relativistic treatment of core electrons?
The relativistic treatment of core electrons is a method used in Density Functional Theory (DFT) calculations to incorporate the effects of special relativity on the movement of these electrons. This is important because core electrons, which are those in the innermost shells of an atom, move at speeds close to the speed of light and thus must be treated relativistically to accurately describe their behavior.
Why is the relativistic treatment of core electrons important in DFT?
The relativistic treatment of core electrons is important because it helps to accurately predict the electronic structure and properties of heavy elements, such as those found in the lower rows of the periodic table. Without considering the effects of relativity, DFT calculations may not accurately describe the behavior of these electrons and can lead to incorrect results.
How is the relativistic treatment of core electrons incorporated in DFT calculations?
In DFT calculations, the relativistic treatment of core electrons is typically included through the use of relativistic pseudopotentials. These are mathematical functions that approximate the effect of the core electrons on the valence electrons, taking into account their relativistic motion. This allows for more accurate calculations of the electronic structure of heavy elements.
What are the limitations of the relativistic treatment of core electrons in DFT?
One limitation of the relativistic treatment of core electrons in DFT is that it is only applicable for single-electron systems, meaning that it does not take into account the interactions between electrons. Additionally, the accuracy of the calculations can be affected by the choice of pseudopotential used, and there may be computational limitations for larger systems.
Can the relativistic treatment of core electrons be used for all elements?
Yes, the relativistic treatment of core electrons can be used for all elements. However, it is most commonly used for heavy elements, such as those with atomic numbers greater than 100, where relativistic effects are more significant. For lighter elements, the effects of relativity are typically negligible and the non-relativistic treatment may be sufficient.
