Relativity: can two observers see two events in reverse?
In summary, S' moves at velocity 0.6c with respect to S, and x=x'=0 at t=t'=0.Two events are recorded.In S, event 1 occurs at x=0 and t=0, and event 2 occurs at x=3000m and t=4μs.At what times does S' say the events happened?Does S' see the events in reverse order from S?S' says the events happened at t'=0 and x'=0, which is when S reaches the origin.
Aziza
190
Clearly S' will also see event 1 at t'=0 and x'=0, but he will say event 2 happened at t'= -2.5μs. This much is right according to my solution manual. However, the solution manual says that S' will SEE the events in reverse order from S.
My argument is that S' will SAY the events happened in reverse order, but he will see them in same order as S (ie, the light from event 2 will not reach S' before S' reaches the origin and sees event 1, because:
According to S', event 2 occurs at x':
x' = γ(x-vt) = 2850 m
However, in the time t = 2.5μs, the light will travel:
x = ct = 750 m
So by the time S' reaches the origin (and sees event 1), the light from event 2 will still be very far away from S', so he must see event 1 before event 2...
am i right or missing something important?
if no one knows the answer to my specific textbook problem can someone just tell me if in general, from your experiences of doing problems, is it ever possible for two observers to actually see two events in reverse order? I have exam coming up and so would like to know at least in general if such a result is at all possible, in which case my above reasoning is probably wrong, so then i will try to find my error better
Yes, it is called the "relativity of simultaneity". Two different observers can, in the right circumstances, disagree on which of two events occurred first.
yes i know that they can SAY two events occurred in reverse order, as in if they calculate backwards, they will disagree on which event actually happened first, but can the light from the two events actually reach each observer in reverse order, so that they will actually SEE the events in reverse order?
I think my textbook is using the words "see" and "say" interchangeably. But i think that even if you "say" two events happened in some order, you will not necessarily actually "see" them in that order?
How would the observers know when they thought the event occurred if the light did not reach them?
no of course the light reaches them, I am not saying it doesn't reach them at all, I am just saying that even if they say two events occurred in reverse order, the light won't necessarily reach them in reverse order, and my general question is if it can even actually reach them in reverse order.
like in my above initial problem, i calculated that the two observers will disagree on the "actual" order of the events. Maybe my initial problem was too detailed to follow and so i will try to simplify and generalize: One observer S' will say that some distant event occurred some time before he reached the origin of another observer S. Once S' reaches origin of S, he sees another event. However, when both origins coincide, the light from the distant event still has not reached neither S nor S'. So even though S' (unlike S) says that the distant event "actually" occurred before the event at the origin (which both S and S' see AND say happened at t=t'=0), both S and S' will see the light from the distant event AFTER they saw the light from the event at the origin, so they will still SEE the events in the same order, even though they disagree on the "actual" order of the events. My solutions manual, however, is saying that they will still "see" the events in reverse order. I am agreeing that they will "say" the events are in reverse order, but i am not agreeing that they will "see" they events in reverse order..
nvm my professor finally emailed me back saying i am right and book made mistake
You need to think of S not just as a single observer, but as a whole team of observers deployed along the x-axis of the S reference frame, and that each member of this team carries a clock that has been synchronized with all the other clocks in the S inertial reference frame. Similarly for the S' reference frame. Now, once you do this, you can determine what individual observers within each of the reference frames observe who are physically present at specific events.
You can also determine how long it takes for light to travel from a specific event to other observer's locations within each of the two reference frames. And, as you noted, you can then determine whether the light from two specific events arrives at any given observer's location within either of the two reference frames, to determine the order at which the light from the two specific events arrives at his location.
But, the implication from the problem statement strongly implies focusing on the times that the two events occurred in each of the two reference frames as measured by the observers physically present at the two events. And, if an observer in a given reference frame is physically present at a specific event, all the other clocks in his reference frame also display this time when the event occurred.
Ohhhh true true if you think of it this way it makes sense, thanks!
FAQ: Relativity: can two observers see two events in reverse?
What is the theory of relativity?
The theory of relativity is a fundamental concept in physics that explains the relationship between space and time. It was developed by Albert Einstein in the early 20th century and has two main components: the theory of special relativity, which deals with objects moving at constant speeds, and the theory of general relativity, which includes the effects of gravity.
How does relativity affect the way we perceive events?
According to the theory of relativity, the perception of events can vary depending on the observer's frame of reference. This means that two observers can see the same event happening at different times or in different orders, depending on their relative motion and position.
Can two observers see two events in reverse?
Yes, it is possible for two observers to see two events in reverse due to the effects of relativity. This is known as "time dilation" and is a consequence of the fact that time is not absolute, but rather depends on the observer's frame of reference. Therefore, two observers moving at different speeds or in different gravitational fields may experience time differently and perceive events in reverse.
How does relativity impact our understanding of cause and effect?
Relativity challenges the traditional understanding of cause and effect, as it suggests that the order of events can be relative to the observer's frame of reference. This means that what one observer may see as a cause, another observer may see as an effect, depending on their relative motion and position.
Can the effects of relativity be observed in everyday life?
Yes, the effects of relativity can be observed in everyday life. For example, the Global Positioning System (GPS) relies on the principles of relativity to provide accurate location and time information. Additionally, the speed of particles in particle accelerators, such as the Large Hadron Collider, must take relativity into account in order to make precise calculations.
