Relevant interactions in quantum field theory
In summary, the interaction term ##\displaystyle{\frac{g}{3!}\phi^{3}}## in a ##\phi^{3}## quantum field theory has a mass dimension of 1 and is considered relevant because it is not negligible at low energies. However, this does not necessarily mean that perturbation theory can be applied at low energies, as quantum field theory is only valid in the relativistic limit.
spaghetti3451
1,344
34
For a ##\phi^{3}## quantum field theory, the interaction term is ##\displaystyle{\frac{g}{3!}\phi^{3}}##, where ##g## is the coupling constant.
The mass dimension of the coupling constant ##g## is ##1##, which means that ##\displaystyle{\frac{g}{E}}## is dimensionless.
Therefore, ##\displaystyle{\frac{g}{3!}\phi^{3}}## is a small pertubation at high energies ##E \gg g##, but a large perturbation at low energies ##E \ll g##.
Terms with this behavior are called relevant because they’re most relevant at low energies.
However, I do not understand why the interaction term is called relevant if we cannot use perturbation theory at low energies (where the term ##\displaystyle{\frac{g}{3!}\phi^{3}}## is a large pertubation). Is it because quantum field theory is only applicable in the relativistic limit, where ##E \gg g## and the perturbation is small ?
The philosophy behind this terminology is that all field theories are only effective theories, which means that they are valid only at large distances (low energies). If a contribution is relevant, it means that it is not negligible. But it does not mean that it is not sufficiently small for application of perturbation theory. For instance, ##\alpha=1/137## is small but not negligible.
FAQ: Relevant interactions in quantum field theory
What is quantum field theory?
Quantum field theory is a theoretical framework in physics that combines the principles of quantum mechanics and special relativity to describe the behavior of subatomic particles and the interactions between them.
What are relevant interactions in quantum field theory?
Relevant interactions in quantum field theory refer to the types of interactions between particles that have a significant impact on the behavior and properties of the system. These interactions are essential for understanding the dynamics and evolution of a quantum field system.
How are relevant interactions calculated in quantum field theory?
The calculation of relevant interactions in quantum field theory involves using mathematical techniques such as perturbation theory and Feynman diagrams to approximate the effects of these interactions on the system. These calculations can be very complex and require advanced mathematical skills.
What is the importance of relevant interactions in quantum field theory?
Relevant interactions play a crucial role in understanding the behavior of quantum field systems. They can determine the stability, energy levels, and other properties of particles, as well as the overall dynamics of the system. Without considering relevant interactions, our understanding of the quantum world would be incomplete.
How do relevant interactions differ from other types of interactions in quantum field theory?
Relevant interactions are distinguished from other types of interactions in quantum field theory, such as irrelevant or marginal interactions, by their relative strength and impact on the system. Relevant interactions have a significant influence on the behavior of the system, while irrelevant interactions have a negligible effect, and marginal interactions lie somewhere in between.
