Resonant Frequency & Natural Frequency?
In summary, there is a relationship between the natural frequency, resonant frequency, and damping ratio. If the damping ratio is 0, the resonant frequency is equal to the natural frequency. There are notes that can help determine the specific relationship, such as the ringing frequency or peak frequency.
dominicfhk
Hello guys! Is it possible to convert a natural frequency to resonant frequency with maybe some kind of formula? I was given a transfer function and I was asked to draw a root locus plot and determine the resonant frequency. I know how to get the damping ratio and natural frequency and the value of K to make the system stable (by using the routh-hurwitz method), but I have no idea how to get the resonant frequency. Thank you so much!
The short answer is "yes" - recall that if the damping ratio is 0, the resonant frequency is the natural frequency: it follows that there is some relationship between the natural frequency, the resonant frequency, and the damping ratio.
You should have notes for these sorts of relationships - like the ringing frequency or the peak frequency.
One of these will be the one you want ;)
Related to Resonant Frequency & Natural Frequency?
1. What is the difference between resonant frequency and natural frequency?
Resonant frequency refers to the frequency at which a system naturally oscillates with maximum amplitude. Natural frequency, on the other hand, is the frequency at which a system will oscillate without any external forces or damping. In other words, resonant frequency is dependent on external forces, while natural frequency is inherent to the system itself.
2. How are resonant frequency and natural frequency related?
Resonant frequency and natural frequency are closely related, as the resonant frequency of a system will always be equal to its natural frequency when there is no damping present. However, when damping is present, the resonant frequency will be slightly lower than the natural frequency.
3. Why is it important to know the resonant frequency of a system?
Knowing the resonant frequency of a system is important because it can help us understand how the system will respond to external forces. If an external force is applied at the resonant frequency, it can cause the system to vibrate with maximum amplitude, potentially leading to damage or failure. Additionally, knowing the resonant frequency can help in designing and optimizing systems for specific purposes.
4. How can we calculate the resonant frequency of a system?
The resonant frequency of a system can be calculated using the formula: fr = 1/2π√(k/m), where fr is the resonant frequency, k is the spring constant, and m is the mass of the system. This formula assumes there is no damping present.
5. Can the resonant frequency of a system be changed?
Yes, the resonant frequency of a system can be changed by altering the parameters of the system, such as its mass or stiffness. For example, increasing the mass of a system will decrease its resonant frequency, while increasing the stiffness will increase its resonant frequency. Additionally, the resonant frequency can also be manipulated by applying damping to the system.
