- #36
meopemuk
- 1,769
- 68
DarMM said:I don't understand this.
What states are the creation and annihilation operators creating and annihilating then? A two particle state at [tex]t=\infty[/tex] is not the same state as a two particle state at [tex]t=-\infty[/tex]. So two different operators are necessary to create them from the vacuum.
Which time corresponds to the plane wave [itex]N\exp(ipx)[/itex]? You cannot assign any time label to it. This is just a single state vector in the Hilbert space. Creation operators create only such plane wave states (or their linear combinations) without any reference to time. You are right when you say: "A two particle state at [tex]t=\infty[/tex] is not the same state as a two particle state at [tex]t=-\infty[/tex]". This is simply because the state vector created at [tex]t=\infty[/tex] has evolved through time into another state vector. But both "infinite past" and "infinite future" state vectors can be build by applying (linear combinations of) the same creation operators to the same vacuum vector.
DarMM said:In/Out states form two completely different basis of the Hilbert space which are related to each other through a unitary transformation known as the S-matrix. So if what you were saying is true, then the S-matrix would be the identity and the theory would be trivial.
This isn't even an aspect of rigorous field theory, it's in usual field theory textbooks like Srednicki.
If you object to this aspect of QFT, you are basically saying all theories are free.
I've never understood what's the idea about separation of the in and out states. Suppose that I've shown you a wave function or a vector in the Hilbert space. Would you be able to tell if this is an "in" state or an "out" state? Or something else? They all look pretty similar to me. The difference is that in "in" states particles are moving toward each other (before the collision), while in "out" states particles are moving away from each other (after the collision). But nobody can forbid me to prepare a state in which particles are moving away from each other at time [itex]t = - \infty[/itex].
Excluding some pathological cases, the S-matrix is not trivial as long as there is a non-trivial interaction between particles. So, most interacting theories are not free.
Eugene.
