Rotating ball flies certain height in the air
In summary, The gravitational potential energy at the beginning at the top is equal to the kinetic energy and rotational energy at the bottom. The rotational kinetic energy at the apex of its final height, plus the potential energy it achieves there, is equal to the initial potential energy. By solving for h using the given equations, we get the final answer of h = 5/7 hi.
nhmllr
185
(answer is h * 5 /7)
gravitational potential energy = mgh
kinetic energy = 1/2 mv2
rotational kinetic energy of sphere = 2/5 mv2
The gravitation potential energy at the beginning at the top is the same as the kinetic energy and rotational energy at the bottom
mghi = 1/2 mv2 + 2/5 mv2 = 9/10 mv2
We also know that the rotational kinetic energy at the apex of it's final height, plus the potential energy it achieves there, is equal to the initial potential energy
mghi = mgh + 2/5 mv2
h = hi - (2/5 v2)/g
and from our first equation, we know
mghi = 9/10 mv2
4/9 ghi = 2/5 v2
So combining those...
h = hi - (4/9 ghi)/g
h = 5/9 hi
But that is not the answer... So where did I go wrong?
Thanks
EDIT: The rotational kinetic energy is actually 1/5 mv2. Sorry, it makes sense
now.The Attempt at a SolutionThe gravitational potential energy at the beginning at the top is the same as the kinetic energy and rotational energy at the bottommghi = 1/2 mv2 + 1/5 mv2 = 7/10 mv2We also know that the rotational kinetic energy at the apex of it's final height, plus the potential energy it achieves there, is equal to the initial potential energymghi = mgh + 1/5 mv2h = hi - (1/5 v2)/gand from our first equation, we know mghi = 7/10 mv23/7 ghi = 1/5 v2So combining those...h = hi - (3/7 ghi)/gh = 5/7 hi
FAQ: Rotating ball flies certain height in the air
How does the rotation of the ball affect its height in the air?
The rotation of the ball can affect its height in the air by creating lift and reducing drag. When the ball is spinning, it creates an area of low pressure on one side and high pressure on the other, resulting in lift that can keep the ball in the air for a longer period of time.
2. What factors determine the height of a rotating ball in the air?
The height of a rotating ball in the air is determined by several factors, including the initial velocity of the ball, the angle at which it is thrown, the amount of spin on the ball, and the air resistance or drag acting on the ball.
3. Can a non-spinning ball reach the same height as a rotating ball?
No, a non-spinning ball will not reach the same height as a rotating ball due to the lack of lift and increased drag. The rotation of the ball helps to counteract the effects of air resistance and keep the ball in the air for longer, resulting in a higher maximum height.
4. How does the density of the air affect the height of a rotating ball?
The density of the air can affect the height of a rotating ball by altering the amount of air resistance or drag acting on the ball. In denser air, the ball will experience more drag and therefore have a lower maximum height compared to if it were in less dense air.
5. Can the height of a rotating ball be accurately predicted?
The height of a rotating ball can be predicted using mathematical equations and models, but there are many variables and factors that can affect the actual height of the ball in real-world scenarios. Factors such as wind, air temperature, and surface conditions can also impact the height of a rotating ball in the air.
