Rotational Motion of two blocks
In summary, the angular acceleration of the pulley is 2Θ/t^2. The acceleration of the two blocks is also 2Θ/t^2. The tensions in the upper and lower sections of the string are equal.
Destrio
212
Two identical blocks, each of mass M, are connected by a light string over a frictionless pulley of radius R and rotational inertia I. One block is on a horizontal plane, one is dangling at the end of the string. The string does not slip on the pulley, and it is not known whether or not there is friction between the plane and the sliding block. when this system is released, it is found that the pulley turns through an angle (theta) in time t and the acceleration of the blocks is constant.
a) what is the angular acceleration of the pulley?
b) what is the acceleration of the two blocks?
c) what are the tensions in the upper and lower sections of the string?
All answers to be expressed in terms of M, I, R, (theta), g and t.
By biggest problem with this question is dealing with the pulley moving at an angle during the motion.
for the dangling block
in the y direction we have the force of gravity and the tension
and no force in the x
for the block on the platform
in the y direction we have no force
in the x direction we have the force of friction and the tension force
the 2 tension forces will be equal so I can relate the 2 blocks
how can I start dealing with the pulley though?
anyone have any hints to help me get started?
thanks
It's just like kinematics... except with angles...
in kinemtics... an object starting from rest:
d = (1/2)at^2
But here:
theta = (1/2)alpha*t^2
solve for alpha.
α = 2Θ/t^2
Atangential = αR
at some point Atangential = a
a = αR
so
αR = 2Θ/t^2
α = 2ΘR/t^2
ΣFy = mg - T1 = ma
ΣFx = T2 - f = ma
T1 = T2
mg - T1 = T2 - f
mg + f = 2T
T = (mg+f)/2
Is this correct?
Thanks
Destrio said:
α = 2Θ/t^2
Atangential = αR
a = αR
so
αR = 2Θ/t^2
α = 2ΘR/t^2
I'm confused by this...
α = 2Θ/t^2
a = αR
so a = 2ΘR/t^2
is that what you meant?
ΣFy = mg - T1 = ma
ΣFx = T2 - f = ma
T1 = T2
mg - T1 = T2 - f
mg + f = 2T
T = (mg+f)/2
Is this correct?
Thanks
T1 is not necessarily equation to T2 in this situation, because the pulley has rotational inertia (ie it is not a massless pulley).
this part is right:
Mg - T1 = Ma
you can use the acceleration you derived before, to solve for T1 (vertical tension).
To get T2 (horizontal tension), use the torque equation for the pulley... you don't know friction, so you can't use that.
sorry yes
α = 2Θ/t^2
Atangential = αR
a = αR
so
αR = 2Θ/t^2
a = 2ΘR/t^2
ΣFy = Mg - T1 = Ma
T1 = Mg-Ma
T1 = M(g-a)
T1 = M[g-(2ΘR/t^2)]
τ = Iα
ΣFx = T2 - τ = ma
T2 = ma + τ
T2 = ma + Iα
T2 = m(2ΘR/t^2) + I(2Θ/t^2)
T2 = (2Θ/t^2)(mR + I)
is this all correct?
Thanks
FAQ: Rotational Motion of two blocks
What is rotational motion?
Rotational motion is the movement of an object around an axis or center point.
How is rotational motion different from linear motion?
Rotational motion involves an object moving in a circular or curved path, while linear motion involves an object moving in a straight line.
What is the relationship between rotational motion and angular velocity?
Angular velocity is the rate at which an object rotates around an axis. The greater the angular velocity, the faster the object is rotating.
How is rotational motion affected by the distribution of mass in an object?
The distribution of mass in an object can affect its rotational motion by changing its moment of inertia. Objects with more mass concentrated farther from the axis of rotation have a greater moment of inertia and are more difficult to rotate.
What are some real-life examples of rotational motion?
Some examples of rotational motion include the spinning of a top, the rotation of the Earth around its axis, and the movement of a wheel on a bicycle.
