Series Convergence/Divergence (II)
  • MHB
  • Thread starter shamieh
  • Tags
    Series
In summary: $\tau$ $\epsilon$ $\varepsilon$ $\zeta(s)$ $\eta^{\ '}(s)$ $\gamma$ $\ln 2$ $-\frac{\ln^{2} 2}{2}$ $\eta$ $\zeta(s)$ $\zeta(s)$ $\zeta(s)$ $\zeta(s)$ $\zeta(s)$ $\zeta(s)$ $\zeta(s)$ $\zeta(s)$ $\zeta(s)$ $\zeta(s)$ $\zeta(s)$ $\zeta(s)$ $\zeta(s)$ $\z
shamieh
539
Determine whether the following series converges or diverges and justify your answer.
\(\displaystyle \sum^{\infty}_{n = 2} \frac{(-1)^n ln(n)}{n}\)
So can't I just apply L'opitals to obtain \(\displaystyle \frac{1}{n}\) which diverges because it is a alternating harmonic series, thus: converges?
So can't I just apply L'opitals to obtain \(\displaystyle \frac{1}{n}\) which diverges because it is a alternating harmonic series, thus: diverges?
Not even close I'm afraid. L'Hospital's Rule is used to find the limit of a function, not anything to do with determining the convergence or divergence of a series.
This is an alternating series, so by LAST (Lagrange Alternating Series Test) the series will converge if the non-alternating part is decreasing.
Consider the function $\displaystyle \begin{align*} f(x) = \frac{\ln{(x)}}{x} \end{align*}$. We have $\displaystyle \begin{align*} f'(x) = \frac{x\left( \frac{1}{x} \right) - 1 \left[ \ln{(x)} \right] }{x^2} = \frac{1 - \ln{(x)}}{x^2} \end{align*}$. This will be negative for all $\displaystyle \begin{align*} x > e \end{align*}$, thereby showing that the function $\displaystyle \begin{align*} f(x) \end{align*}$ is decreasing for all $\displaystyle \begin{align*} x > e \end{align*}$.
This at least shows that $\displaystyle \begin{align*} \sum_{n = 3}^{\infty}{ \frac{(-1)^n \ln{(n)}}{n} } \end{align*}$ is convergent. If you add the extra term where $\displaystyle \begin{align*} n = 2 \end{align*}$, you will simply be adding two finite numbers, thereby still giving you something finite. So the series you have given is also convergent.
So I can't do this ? :
\(\displaystyle \sum^{\infty}_{n = 2} (-1)^n \frac{ln(n)}{n} = n\to\infty \frac{1/n}{1} = 0\)
now since \(\displaystyle \lim a_n = 0 \) using AST , \(\displaystyle 0 < \frac{1}{n+1} < 1/n\) so the series converges using alternating series test?
The series converges for the Leibnitz's criterion. Remembering the definition of the Dirichlet Eta Function...
$\displaystyle \eta(s) = - \sum_{n=1}^{\infty} \frac{(-1)^{n}}{n^{s}} = (1 - 2^{1-s})\ \zeta(s)\ (1)$... where $\zeta(*)$ is the Riemann zeta function. Deriving (1) we obtain...
$\displaystyle \eta^{\ '}(s) = \sum_{n=1}^{\infty} \frac{(-1)^{n}\ \ln n}{n^{s}} = 2^{1-s}\ \ln 2\ \zeta(s) + (1 - 2^{1-s})\ \zeta^{\ '} (s)\ (2)$
... and with a little of patience you can demonstrate that is $\displaystyle \eta^{\ '} (1) = \gamma\ \ln 2 - \frac{\ln^{2} 2}{2}$, where $\gamma = .5772...$ is the Euler's constant... Kind regards $\chi$ $\sigma$
FAQ: Series Convergence/Divergence (II)
What is the definition of series convergence?
Series convergence refers to the property of a series, where the sum of its terms approaches a finite value as the number of terms increases towards infinity.
How do you determine if a series is convergent or divergent?
There are several methods for determining the convergence or divergence of a series, including the comparison test, the ratio test, and the integral test. These tests involve comparing the given series to a known series with known convergence properties.
What is the difference between absolute and conditional convergence?
Absolute convergence refers to the convergence of a series where the absolute values of the terms are considered. Conditional convergence, on the other hand, refers to the convergence of a series where the terms may alternate between positive and negative values, but the sum still approaches a finite value.
Can a series be both convergent and divergent?
No, a series can only be either convergent or divergent. If a series is convergent, it means that the sum of its terms approaches a finite value, while a divergent series does not have a finite sum.
Why is it important to determine the convergence or divergence of a series?
Determining the convergence or divergence of a series is important in various fields such as mathematics, physics, and engineering. It allows us to understand the behavior and properties of the series and can be used to solve real-world problems and make accurate predictions.
