Show equation has exactly one root
  • Thread starter darius
  • Tags
    Root
In summary, the equation f(x)=3x-2+cos(Piex/2)=0 has exactly one real root. This can be shown using the intermediate value theorem and Rolle's theorem. By setting up the equation f'(x)=3-(pie/2)(sin(piex/2))=0, it can be seen that there is a root in the interval (a,b). However, since sin(pi*x/2) is always greater than zero for all real x, this is impossible and therefore the equation can only have one real root.
darius
The question is show that the equation f(x)=3x-2+cos(Piex/2)=0 has exactly one real root.
Using the intermediate value theorem f is continuous and f(o)=-1 and f(1)=1., the equation has one root. Supposing it has two roots a and b , and
a<b. Then f(a)=0=f(b). Using Rolle's theorem there is a number d in (a,b) such that f'(x)=3-(pie/2)(sin(piex/2))=0 has a root in (a,b). But this is impossible since after factoring sin(piex/2)=6/pie is always greater than zero for all real x. I am having problems with factoring. Why is 3-(pie/2)(sin(piex/2))always >o for all x?
First it's pi not pie. Now for your question as to why it is always greater than zero this is because you reduced this to sin(pi*x/2) = 6/pi, but the range of the sine function is only from -1 to 1, and you should notice that 6/pi is greater than 1 hence 3 - (pi/2)(sin(pi*x/2)) is always greater than 0 for real x.
thank you so much. Sometimes, we have a hard time seeing the easiest step after going though the hard steps! I am just beginning calculus and I am starting college in the fall. Thank you! P. S. today was my first day at this forum!
Yes I know exactly what you mean, I'm glad i could help and welcome to the forums.
FAQ: Show equation has exactly one root
What is an equation with exactly one root?
An equation with exactly one root is an equation where there is only one value that satisfies the equation. This means that when the equation is graphed, there is only one point where the line crosses the x-axis.
How can you determine if an equation has exactly one root?
An equation has exactly one root if the discriminant, which is the part of the quadratic formula under the square root sign, is equal to zero. This means that there is only one solution to the equation.
What does it mean when an equation has multiple roots?
When an equation has multiple roots, it means that there is more than one value that satisfies the equation. This can be seen on a graph as multiple points where the line crosses the x-axis.
Can an equation have no roots?
Yes, an equation can have no roots. This means that there is no value that satisfies the equation and when graphed, the line does not cross the x-axis. This is also known as having no solutions.
How can knowing an equation has exactly one root be useful?
Knowing an equation has exactly one root can be useful in solving real-world problems. It allows us to find a single solution or answer to a given problem, rather than having multiple or no solutions. It can also help us to better understand and analyze the behavior of a system or process.
