Whatever123
- 20
Prove that if two matrices are similar then they have the same eigenvalues with the same algebraic and geometric multiplicity.
Matrices A,B are similar if A = C[tex]\breve{}[/tex]BC for some invertible C (and C inverse is denoted C[tex]\breve{}[/tex] because I tried for a long time to figure out how to get an inverse sign in latex but couldn't figure it out...).
To show that two similar matrices have the same eigenvalues with the same geometric multiplicities, I need to show that their characteristic polynomials are the same.
Let A,B be similar matrices. Then,
A = C(inverse)BC
A-[tex]\lambda[/tex]I = C[tex]\breve{}[/tex]BC - [tex]\lambda[/tex]I
A-[tex]\lambda[/tex]I = C[tex]\breve{}[/tex]BC - [tex]\lambda[/tex]C[tex]\breve{}[/tex]C since C[tex]\breve{}[/tex]C=I
A-[tex]\lambda[/tex]I = C[tex]\breve{}[/tex][B-[tex]\lambda[/tex]]C
det(A-[tex]\lambda[/tex]I) = det(C[tex]\breve{}[/tex][B-[tex]\lambda[/tex]I]C)
det(A-[tex]\lambda[/tex]I) = det(C[tex]\breve{}[/tex]det(B-[tex]\lambda[/tex]I)det(C)
det(A-[tex]\lambda[/tex]I) = det(C[tex]\breve{}[/tex])det(C)det(B-[tex]\lambda[/tex]I)
Therefore, det(A-[tex]\lambda[/tex]I) = det(B-[tex]\lambda[/tex]I)
So, A, B have the same characteristic polynomials. This implies that they have the same eigenvalues with the same algebraic multiplicity. However, I do not think that this implies that they have the same geometric multiplicity because it doesn't same anything about the dimension of the eigenspace. Does it? Any suggestions on how I should try to show that the geometric multiplicity is the same?
So does anyone have any advice? I spent a while to get the first part, I just could use a nudge in the right direction for the next part... Thanks in advance.
