Simple cosine expression NOT so simple
In summary, the conversation is about a person who is trying to integrate a mathematical expression, but is struggling to find a solution. They have tried various methods, but have not been successful. The conversation also mentions the use of an integrator on Wolfram's website, which ultimately helps the person find the solution.
Mark Wood
I am rediscovering my long lost "A" level maths and have been having lots of fun working on puzzles. Unfortunately, I seem to have hit something of a wall in the following simple expression that is repelling every attack I launch:
f(x)=[tex]Sqrt[/tex](1+kcos(x))
I have tried substituting x=arccos(w) and w=arccos(w/k), expressing things as logs, mungeing the equations I get, and a number of slightly more desperate attacks, but whatever I do to get rid of one term or provide something that can be canceled out, a new problem pops up.
I feel that there is a simple answer to this, but the more I look at it the less I can see the way forward.
Any suggestions anyone?
What exactly do you want to do with f(x)?
Ah! So absorbed by it, I've missed the most important bit!
I'm trying to integrate it to get the area under the curve between x=0 and x=pi
Sorry, i couldn't get ur expression. is it (1+kcos(x))^(1/2)
Yes it is - the root of (1+kcos(x))
I don't think it has a solution made up entirely of elementary functions. Elliptic functions may be involved.
I too struggled for it for 6-8 months. Its a kind of elliptic integral(which i didn't knew). u might be knowing. u can check it on an integrator at www.wolfram.com
Gosh - what a great tip. I didn't know the integrator existed. Thank you.
Having got the answer from Wolfram I'm kind of pleased that I hadn't missed an obvious solution.
Thank you all.
FAQ: Simple cosine expression NOT so simple
What is a simple cosine expression?
A simple cosine expression is an algebraic expression that involves the cosine function, which is a mathematical function that relates the ratio of the adjacent side to the hypotenuse in a right triangle. The expression can include constants, variables, and other mathematical operations, but it must include the cosine function.
Why is a simple cosine expression not so simple?
A simple cosine expression may seem straightforward, but it can become complex when it is used to model real-world phenomena or when it is combined with other mathematical functions. Additionally, the cosine function itself can have multiple properties and identities that can make the expression more intricate.
How is a simple cosine expression used in science?
Simple cosine expressions are commonly used in physics, engineering, and other scientific fields to model periodic functions, such as sound and light waves. They can also be used to represent physical quantities, such as a particle's position or velocity, in terms of cosine functions.
What are some common properties of a simple cosine expression?
Some common properties of a simple cosine expression include its periodicity, symmetry, and amplitude. The periodicity refers to the fact that the expression repeats itself at regular intervals, while symmetry refers to the shape of the graph of the function. The amplitude is the maximum value of the expression.
How can I simplify a simple cosine expression?
There are several techniques for simplifying a simple cosine expression, such as using trigonometric identities, factoring, or using the unit circle. It is also helpful to remember the key properties of cosine, such as the values of cosine for common angles, to simplify the expression further.
