Simple Harmonic Motion Problem Help
In summary, the conversation discusses the calculation of the amplitude, phase angle, and position equation for a 2.00 kg frictionless block attached to an ideal spring with force constant 300 N/m. The angular frequency is found using the equation w=√(k/m) and is equal to 12.25 rad/s. The equation for position can be written as x=Acos(ωt+θ) or Asin(ωt+ψ), with the same results. The choice of using either form depends on the starting position of the object.
bdh2991
103
a 2.00 kg frictionless block is attached to an ideal spring with force constant 300 N/m. at t=0 the spring is neither stretched nor compressed and the block is moving in the negative direction at 12.0 m/s. Find the amplitude, the phase angle, and write and equation for the position as a function of time.
i used w=√(k/m) to find the angular frequency. i get w=12.25 rad/s
then, I'm assuming that when x=0, the cos(θ) must equal zero, in the equation x=Acos(wt+θ)
solving for θ i get θ=∏/2.
after that i used v=-wAsin(wt+θ), to find the amplitude, which i got the amplitude of 0.98m
I believe i got the phase angle and amplitude with the right concepts of simple harmonic motion, except i can't figure out how to get the right equation of x(t). i always thought x(t) was supposed to have a cos function in it, however the answer in my book says it is a sin function. If someone could explain this to me i would greatly appreciate it.
Your results are correct. You can write the displacement during SHM in both ways: x=Acos(ωt+θ) or Asin(ωt+ψ)-they are the same with appropriate choice of the phase constants cos(ωt+θ)=sin(ωt+θ+π/2).
When the object starts from maximum displacement x=A, it is convenient to use the cosine form, as it involves zero phase constant, but the sine form is better to use when the object starts from equilibrium x=0: x=Asin(ωt).
ehild
thanks for explaining that to me!
FAQ: Simple Harmonic Motion Problem Help
What is Simple Harmonic Motion?
Simple Harmonic Motion refers to the repetitive back and forth motion of an object around an equilibrium point. This motion is caused by a restoring force that is proportional to the displacement of the object from its equilibrium position.
How do you solve Simple Harmonic Motion problems?
To solve Simple Harmonic Motion problems, you will need to use the equation T = 2π√(m/k), where T is the period of motion, m is the mass of the object, and k is the spring constant. You will also need to use the equations x = Acos(ωt) and v = -ωAsin(ωt) to find the position and velocity of the object at any given time.
What is the relationship between period and frequency in Simple Harmonic Motion?
The period (T) and frequency (f) in Simple Harmonic Motion are inversely proportional. This means that as the period increases, the frequency decreases, and vice versa. The relationship between the two is given by the equation T = 1/f.
Can Simple Harmonic Motion occur without a restoring force?
No, Simple Harmonic Motion requires a restoring force to occur. The restoring force is responsible for pulling the object back to its equilibrium position after it has been displaced.
How does amplitude affect Simple Harmonic Motion?
The amplitude (A) in Simple Harmonic Motion determines the maximum displacement of the object from its equilibrium position. As the amplitude increases, the displacement also increases, resulting in a larger range of motion for the object.
