Simple Pendulum in an elevator
In summary, the Lagrangian equation of motion for a simple pendulum of length l suspended from the ceiling of an elevator that is accelerating upward with constant acceleration a is L=Kinetic energy- potential energy=T-U. The attempt at a solution uses the freshman physics kinematic equations to include the contribution from the acceleration and finds that T=1/2ml2\phi ' 2 (the phi has a prime, its hard to see) and U=mgl(1-cos\phi). However, the problem statement assumes that the elevator is in a small angle reference frame, so these two velocities are orthogonal and it works out.
Jumblebee
Using the usual angle [tex]\phi[/tex], as generalized coordinate, write down the Lagrangian for a simple pendulum of length l suspended from the ceiling of an elevator that is accelerating upward with constant acceleration a. Find the Lagrangian equation of motion and sho that it is the same as that for a normal, nonaccelerating pendulum except that g has been replaced by g+a.
Lagrangian is L=Kinetic energy- potential energy=T-U
I need to find the kinetic energy and potential energy, which i know that T=1/2mv2 and U=mgh.
So I think that T=1/2ml2[tex]\phi[/tex] ' 2 (the phi has a prime, its hard to see) and
U=mgl(1-cos[tex]\phi[/tex])
However, I don't think that these are right because I didn't do anything with the fact that it is in an elevator accelerating. Any help?
Your generalized coordinate system is inconsistent with the motion of the elevator. The potential energy will change for two reasons: 1) the pendulum bob swings up and down, and 2) the elevator changes elevation. The kinetic energy can "always" be written as T=(1/2)mv^2, but this v is no longer simply an angular motion because you also have to account for the motion due to the changing elevation of the elevator.
Okay, so I need to fix my velocity, but I don't really know what to do with it, the only thing i know about it is that it is moving up with a constant acceleration, but then what happens with the phi?
First try writing the Lagrangian in terms of x,y components, and you can use the freshman physics kinematic equations to include the contribution from the acceleration. However, I'm not suggesting that this should be the end result, but it may be the easiest way to see how the elevator motion and position enters into the Lagrangian and the constraint from the rod to get you started.
You shouldn't need to go to x and y. I assume you're allowed to have a non-inertial reference frame, so SImply add terms to U and T to account for the elevator motion
The height of the elevator assuming initial height and velocity of zero is
h=(a(t^2))/2
Where "a" is the elevator's acceleration
Thus
U=mgl(1-cos) + (mga(t^2))/2
u = mg{(1-cos) + at^2/2}
As you can see, the component in brackets is the actual height accounting for both motions.
Now you also have an additional velocity component ...
Velocity as a function of time for an acceleration a is...
v = a t
You need to be carefull when doing kenitic energy this way. Technically, you would need to find a final velocity vector combining both elevator and pendulum motion, then square that velocity. However, we assume SMALL ANGLE, thus, these two velocities are orthogonal and it works out.
For the kenitic energy because of the elevator's motion...
Ke = (1/2) m (at)^2
Combining to get total kinetic energy, you can see...
T = (1/2) m {(l phidot)^2 + (at)^2}
As you can see, the quantity in curly brackets is simply the square of the TOTAL velocity vector
I assume that the missing "l" is just a typo. It's too bad we didn't get to see Jumblebee figure this one out.
flatmaster said:
... we assume SMALL ANGLE, ...
Who's "we"? I don't. I didn't see that in the problem statement.
so the Lagrangian equation of motion would be -mgl(1+sin phi)=ml^2phi 2dots right?
Related to Simple Pendulum in an elevator
What is a simple pendulum?
A simple pendulum is a weight or mass attached to a rod or string that is able to swing freely back and forth.
How does the motion of a simple pendulum change in an elevator?
In an elevator, the motion of a simple pendulum will be affected by the acceleration of the elevator. As the elevator moves, the pendulum will swing back and forth in a curved path instead of a straight line. The acceleration of the elevator will also affect the period and frequency of the pendulum's motion.
What factors affect the motion of a simple pendulum in an elevator?
The motion of a simple pendulum in an elevator is affected by the acceleration of the elevator, the length of the pendulum, and the mass of the weight at the end of the pendulum. These factors can change the period and frequency of the pendulum's motion.
How does the motion of a simple pendulum in an elevator differ from a stationary pendulum?
In a stationary pendulum, the only force acting on the pendulum is gravity. However, in an elevator, the acceleration of the elevator adds an additional force that affects the pendulum's motion. This can cause the pendulum to swing in a curved path and change its period and frequency.
Can the motion of a simple pendulum in an elevator be used to determine the acceleration of the elevator?
Yes, by measuring the period and frequency of the pendulum's motion in the elevator, the acceleration of the elevator can be calculated using the equation a = 4π²L/T², where a is the acceleration, L is the length of the pendulum, and T is the period of the pendulum's motion.
9K
