davie08
- 115
simplify each expression: 2(4-h)^2-32/h
I forget if I should multiply the 2 into the 4-h.
The expression "2(4-h)^2-32/h" is an algebraic expression that contains variables and numbers. It represents a mathematical calculation that can be simplified to a single value.
To simplify the expression "2(4-h)^2-32/h", you can use the rules of algebra to expand and simplify the terms. This process involves substituting values for the variables and performing the necessary mathematical operations.
Simplifying expressions is important because it allows us to find the most basic and concise representation of a mathematical calculation. It also helps us to solve more complex equations and make connections between different mathematical concepts.
Common mistakes to avoid when simplifying expressions include forgetting to distribute the coefficients, making errors in the order of operations, and failing to combine like terms. It is important to carefully check each step of the simplification process to avoid these mistakes.
Yes, the expression "2(4-h)^2-32/h" can be simplified further by combining like terms and performing any remaining mathematical operations. The simplified expression will result in a single value that represents the solution to the original equation.
