Soleniod Field Direction With Battery
In summary, the conversation discusses the direction of magnetic field lines in a solenoid attached to a battery. The websites provided have differing explanations, but the use of the Right Hand Rule can help determine the correct direction.
adabistanesoophia
Hi
I am very confused that when a solenoid is attached with a battery then where its lines of forces will be directed? ie from +ve to -ve or from -ve to +ve ?
I ahve visited these two websites but both have different answers for same situation.
http://www.physchem.co.za/Current10/Magnetic1.htm#solenoid"
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/elemag.html#c4"
So guide me.
Regards,
Rizwan Khalil
923214120424
:smile:
adabistanesoophia said:
Hi
So guide me.
Regards,
Rizwan Khalil
923214120424
:smile:
Your first link does not work.
The second link shows the correct direction of the magnetic field (these should not be called "lines of force") given the direction of the current shown. Using the fact that the current flows out of the positive terminal of a battery an dinto the negative terminal of the battery you can tell that (if you look at the "electromagnet" picture shown at the bottom of the website), the bottom wire would be connected to the positive terminal of the battery and the top wire would be connected to the negative terminal of the battery.
Hope this helps
Patrick
Hi adabistanesoophia, and welcome to PF. Have you learned how to use the Right Hand Rule yet to tell you which way the magnetic field lines are directed around a current? That's the easiest way to keep the directions straight.
FAQ: Soleniod Field Direction With Battery
What is a solenoid field direction?
A solenoid field direction refers to the direction in which the magnetic field is produced by an electric current flowing through a solenoid, which is a coil of wire. This direction is determined by the right-hand rule, where the fingers of the right hand curl in the direction of the current and the thumb points in the direction of the magnetic field.
How is the solenoid field direction affected by a battery?
A battery is the source of energy that powers the electric current flowing through the solenoid. The direction of the current will depend on the polarity of the battery, which will determine the direction of the magnetic field produced by the solenoid.
Does the solenoid field direction change when the battery is reversed?
Yes, when the battery is reversed, the direction of the current flowing through the solenoid will also reverse, resulting in a change in the direction of the magnetic field produced by the solenoid.
What is the significance of the solenoid field direction?
The direction of the solenoid field is important because it determines the direction of the force that another magnetic object will experience in the presence of the solenoid's magnetic field. It also plays a crucial role in applications such as electromagnets and electric motors.
Can the solenoid field direction be controlled?
Yes, the solenoid field direction can be controlled by changing the direction of the current flowing through the solenoid. This can be achieved by reversing the polarity of the battery or by using a switch to change the direction of the current flow.
